Question about Refrigerators
Plugged fridge in after not using 4 12 months and it is not getting cold
  • 2,133 Answers
Check power to relay. And compressor is working by keeping arm in condenser coil to feel warm. Sometime, after long interval if you use it, there may be chance for system chocking. Call repairman and check.Thanks.
Posted on Mar 20, 2011
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Frigidaire fridge stored and unplugged for 6 months. Today I plugged it in again. The light comes on in the fridge but the fridge did not get cold at all. what should I do?
check your setting. it could have be turned off at the control settings. also give it at least 24 to 48 hours to before storing food.
May 02, 2011 | Frigidaire Refrigerators
The fridge has been unplugged for about 6 months due to renovations. When plugged in only the freezer works. The fridge section will not kick in. Is there a reset button? Thanks Cindy
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 30, 2011 | Kenmore Top Freezer Refrigerator
106.56532400 this is the model number for my fridge I moved fridge from home to storage left it for 2 weeks brouhgt it back home let it sit for 2 days then plugged it in and did not freeze or get cold i...
sound like there is a leak at the tap he installed or in the evaporator. call him back and have him to repair it right. He should have checked for leaks.
Dec 17, 2010 | Kenmore Refrigerators
Maytag PBF2253HEW; freezer fan not working and fridge not getting any cold air. Ice maker only dropping about every 6 - 8 hrs. What needs to be replaced? (This was a friend's refrigerator, he used for 2...
Mark Remove the rear panel in freezer. Apply 3n1 oil to fan motor shaft and plug in and spin. I believe they left the freezer shut and the moisture froze the shaft on fan with rust. Once restarted you will be fine. Sea Breeze
Jan 27, 2010 | Refrigerators
Whirlpool ET18NK fridge does not get cold but freezer is ok. The freezer portion is around 15 degrees, but the fridge wont get colder that about 53 degrees. The house was empty for about 6 months, and we...
If the fan is frozen this would be cause because something in the defrost system is bad. Or you could have a open motor. Make sure the door gasket is sealing.
Mar 08, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
