Question about Home Security
Fitted a yale wireless alarm soon has i open my front door alarm bells ring like im burglar alarm goes off not just beeb beep proper sirens in and out
You need to go into the devices menu then the edit devices menu and then programme your door contact as an entry device. All devices when first added to the system default as burglar and activate immediately. You have to tell the system which devices you would lke a delay on.
I install Yale Alarms throughout Yorkshire
Posted on Jun 02, 2012
  • 783 Answers
Call the security company. you probable programmed it wrong or installed a sensor wrong or something.
Posted on Mar 20, 2011
I have a Yale Easy Fit Standard Alarm (EF-BX) Sometimes when I enter my house and enter my code in the keypad, the siren doesn't bleep twice to turn it off, I re-enter the code and sometimes this works and...
If you are sure you are pressing the buttons firmly.....does it register on the keypad? If so then could be faulty....return it to manufacturer, they will test it before replacing!
Jan 31, 2015 | Cars & Trucks
My 2002 GMC Yukon XL has never done this before and all of a sudden when I unlock the car with a key and open the door the burglar alarms goes off. When I use the key FOB no alarms go off. How do I
It's kind of mix problems , there is two kind of alarms
1...one for burglars alarms if someone try to break window and unlock from Inside lock
2....alarms for car finder on key fob
Oct 07, 2014 | 2002 GMC Yukon XL
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Alarm beeps every 5 mins. I have changed battery and problem still persists.
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Nov 22, 2010 | Industrial Home Security Burglar Alarm...
Have a 1998 lincoln continental that has factory alarm. but i dont have a keypad. i would like 2 disarm it, it goes off for no reason.
if its an aftermarket alarm, which im sure it is, find the brain to the aftermarket alarm and unhook it. trace the brain back from the car alarm siren hardware. it shoud b mounted somewhere under the hood. theres not a lot of available space in the engine compartment. so you should easily find the siren hardware. trace the wiring back to the brain and disconnect it. it cant be factory alarm. factory alarm only goes off when u dont use keyless remote or key to unlock a locked door or trunk. factory alarm blows horn and blinks parking lights
May 26, 2010 | 1998 Lincoln Continental
Ge simon 2 alarm no longer beeps after battery replaced
Probably knocked off the clip on the piezo. Open the box and make sure all plugs are plugged into the circuit board.
AlarmProfessor.net
May 20, 2010 | GE Security Simon 3 Wireless Home Security...
Do you have a diagram on how to open my FAi security system box to change the main battery it it the model that runs on battery only plugs in the bottom, siren up the top digital display and sensor at the...
if you open case, probably have 2 to 3 hours of continuing siren on. this a protection switch who alarm firesup evan is in off mode, there a screw on case, to close all, but has security switch. you must open
Feb 21, 2010 | Heartland Door Stop Burglar Alarm - 118db
How do I turn system beeps off for sirens
My problem started when the electricity went off so now everytime I open the door the siren goes off. I don't have a manual so how can I get this to turn off.
Jun 18, 2009 | GE Security Simon 3 Wireless Home Security...
Bmw e36 1996 318is
If ews2 alarm is fitted it need to be reset by computer. Any tampering will set it into protectction mode. Had similar problem. You can try the following but if it does not work get someonr with diagnostic computer. PREPARATION 1. Close all doors, trunk, hood and sunroof. 2. The security system must be in 'disarm' mode. The key must be removed from the ignition key slot. ENTER CODE LEARNING MODE 3. Open trunk and leave it opened. 4. Open the drivers door and sit in the drivers seat. 5. Close the drivers door. 6. Cycle the ignition switch 5 times between the 'OFF' position and position 2,(ignition 'ON', all dash warning lamps will illuminate). The red status LED will illuminate continuously, and the siren will 'chirp' once, to indicate that the code-learning mode has been initiated. ?Do No start the engine.? The Ignition switch cycling in step #6 must be performed within 10 seconds. The sequence in steps #1-#6 must be performed within 45 seconds. REGISTER/DELETE ID CODE(S) 7. Open drivers door, (remain seated in the drivers seat) 8. Close the drivers door. 9. Press and release any button on the remote you wish to register in the system. The status LED will shut off momentarily to indicate that one code has been registered. 10. Repeat steps 7 thru 9 to register the three ID codes. It is possible for the system to memorize a total of 4 different ID codes. As a new code is initialized into the memory, the oldest code is automatically deleted. If you had lost your remotes and wished to delete the lost remote ID codes from the memory, you could initialize the ID codes from a newly purchased replacement transmitter four times thereby deleting the previous ID codes from the system memory. EXITING CODE - LEARNING MODE: 11. Open drivers door, and exit from the vehicle, leaving the door opened. 12. Close trunk. 13. Close drivers door. The LED will turn off and the siren will 'chirp twice. 14. The initialization procedure is now completed; Test all remotes to confirm operation.
Jul 01, 2008 | 1996 BMW 318
Home Security Logo
387 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
