Question about Whirlpool Washing Machines
Error F05 on my awod as147 steam washing maching
    Brigadier General:
  • 6,277 Answers
F05 for Whirlpool washers decodes as 'NTC failure'. NTC stands for Negative Temperature Co-efficient and all that means is the water temperature sensor ;-0)
I have heard that occasionally it can be brought back to life by pouring in a few kettles of hot water into the washer, leaving for 10 minutes, spinning the water out and re-trying. If it doesn't work it means a service call. Sorry ;-0(
Good luck,
John C.
Posted on Mar 20, 2011
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have a Duet GHW9250MWO washer; got an F05 error. What do we do?
An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Eleme
Mar 10, 2010 | Whirlpool GHW9250M Front Load Washer
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
361 people viewed this question
Dan Webster
Dan Webster
Sal De
