Question about Nikon COOLPIX S200 Digital Camera
My cd users manual was stolen, a just bought it a couple of days and now, the battery is empty.whats the procedure on how to charge it? my digi cam is Nikon s205.what i have here is a usb and a n adapter.can i plug it to a 220a/c directly?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Yes, you may plug the EH-68P adapter into a 220V source. One end of the USB cable plugs into the adapter, the other end plugs into the USB socket on the bottom of the camera.
You can download a copy of the manual from
http://support.nikonusa.com/app/answers/detail/a_id/17066
Posted on Mar 20, 2011
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 | Cameras
No connection when trying to charge battery
hello there!
i will help with your problem. just follow these steps.
1. remove the battery and memcard. 2. put it back and make sure that it properly put.3. connect the cable of the charger and charge it.4. make sure that the charger is properly plug in in the socket and in your digi cam.5. if still not charging, try to charge to other power outlet.
if still not working, call a service center or an authorized repair shop and ask them to check your digi cam. there must be a problem inside.
thank you for choosing fixya and kindly rate my post.
Jan 25, 2012 | Olympus STYLUS TOUGH 8010 Digital Camera
How i can recharge canon digi cam
The A480 uses two AA batteries. If you want to use rechargeable batteries, you must charge them in a separate charger. The A480 does not include any charging circuitry.
Nov 17, 2010 | Canon PowerShot A480 Digital Camera
Eco-drive BT0054-59E not charging.
I know what the manual says, but I have found that sometimes it can take a few days to charge.
I set mine directly under a UV lamp for at least a day to charge. I have found the PULLing the STEM OUT and setting it under a lamp to charge works the best. Try for a couple days, one day stem out another stem in.
If it still does not charge it may need a new secondary battery.
Citizen offers a good warranty on that secondary battery/ power cell and if it's just a few years old they should replace it for free.
This really is not something you should try to fix yourself as the cells are easy to mess up.
Good luck.
Oct 23, 2009 | Watches
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Fun mode and batteries
Dont use Ni-cd batteries, only NiMH or the new "Oxy" batteries from Panasonic, 5X the power of Alkaline and higher voltage, GREAT disposable battery for a Digi-cam. Some cams will NOT work on the old zinc batteries, even brand new. Fun mode is probably just to edit anyway, probably not a shooting mode.
Feb 25, 2008 | Samsung Digimax S630 Digital Camera
Samsung c630
Just bought one recently, and experienced a melt down like that..
What batteries are u using?..
This cam uses lots of power and i started off with 2700 rechargeables, after their 1st charge they emptied fairly quickly, after shutting the cam down for a few mins, they soon picked up again, i was using flash everytime, i guess this was the problem... When my rechargeables started to run down, the cam acted weirdly.... i think ur problem may be because of batteries weakening at that particular time??
Are you aware whether ur batteries were full or nearing empty at the time??
Colin
colinfenning@yahoo.co.uk
Dec 15, 2007 | Cameras
Panasonic Digital Camera
ask the person to visit the shop from where he bought the didi cam and tell the serial number...only they can tell as they have too keep recrd for legal reasons as the digi cam must have been discontinued by the manufacturer.
Nov 01, 2007 | Cameras
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
218 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
