Question about Philips Televison & Video
My dvd player phillips dvp3040/37 always shows "no
  • Philips Master
  • 2,098 Answers
Hi tcpascual,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust the lens can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replace the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 20, 2011
I bought some "Sony" DVD-RW
Most VCR/DVD combo players cannot read DVD-RW Discs. You may need to use DVD+R or DVD-R discs instead.
Please rate my solution to show your appreciation!
Jun 03, 2011 | Computers & Internet
When trying to watch DVD the DVD player does not read the disc and shows the "smart navis" screen. the model is; Wharfedale 3210dvx does not see disk
Hello.
Please verify the disc maybe not compatible with your DVD player, or maybe damage on it. please try another disc. besure that the disc has no rashes;.
Mar 31, 2008 | Televison & Video
My phillips HTS3105/98 shows "no
The laser disc reader has failed. This could be caused by multiple things, most likely its not worth the repair however there are facilities that specialize in this. I would assume maybe try to sell it and go buy a new DVD player.
May 04, 2011 | Audio Players & Recorders
My dvd player phillips dvp3040/37 always shows "no disc". please help me.
Get a dvd cleaner disc. Or take it apart and clean it. Sounds like a dirty lens.
Mar 20, 2011 | Philips DVP5140 DVD Player
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My toshiba sd-3205 will not load any of my DVDs anymore, the discs I insert into the player are in perfect condition and have loaded previously when the DVD player was working. it always says...
Probably dirty pick up lens.
Get a lens cleaning disc and run that and see if that cures problem.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba SD-3205 Multi-disc DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Want to unlock my philips lx8300sa dvd player to multiregional ?
I have a Phillips DVD Player Model DVP5500S for more than a year it functioned very well when suddenly it shows No Disc all the time. After sort of cleaning . It now plays VCDs but not DVDs.I notice the unit always disc lock after a VCD is shown. What could be the problem? Please help.
Jimmy - Philippines
Sep 17, 2008 | Televison & Video
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Feb 02, 2008 | Televison & Video
Televison & Video Logo
455 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
