Question about Roland Cube-20x (20w 8" Modeling Guitar Amp)
My Roland Cube 20x Amp doesn't switch on after a sudden voltage increase! I turned the power supply off in a jiffy though!
  • Roland Master
  • 5,603 Answers
Thee internal fuse should have protected it.
Here is schematic:
http://elektrotanya.com/roland_cube-20_combo_sch.gif/download.html
Scroll down on page and click on "Get Manual"
Posted on Mar 20, 2011
    Problem Solver:
  • 10 Answers
If you take your speaker out you can see if it has blown the internal fuse if not it could be the exernal fuse the power adaptor
Posted on Aug 12, 2011
Will a tascam m1600 function correctly without a specific power supply?
As long as your power supply is supplying the correct voltage and the amp rating is sufficent, and of course the power supply itself is functioning, then your problem is more likely to be a routing error somewhere.. it's probavbly best to center all controls, disengage all switches, and start over from nothing. You should also check that what ever you are using to hear the signal is functioning correctly as well.
Dec 28, 2015 | Roland Music
Roland street cube won't power on due to battery acid leak
Most likely the acid ate the internal power supply, but if you can dis-assemble it and clean any trace of gunk with a toothbrush and electronic cleaner, including the fuse and it's contacts, maybe you'll get lucky.
Nov 07, 2014 | Roland CUBE Street Amp Combo
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
Roland cube street water damage repair
What part of it got wet will determine the course of action.
If the whole unit were submerged, the unit may prove more time consuming to try to fix than to locate a used one. However, I have salvaged imersed laptops before. the procedure is not much different- make sure the unit is as dry as you can possibly make by blowing a fan on it for an extended period of time.- Days.
Once dried, use some contact cleaner on the jack contacts and interupts, any manual control and any switch.
You can then apply power. If nothing lights up, check and replace fuses as needed. Also check the power supply board for failed caps or rectifiers.
Once the power supply is known to be functional, systematically check the LCD display and the aspects of the amp that it controls. This board will be the most vulnerable and most likely to be the source of most issues you will encountr.
If the display survived intact, and amp does nto work, apply a signal to the inputs and trace the signal through the amp with a set of headphones set up with test prods. The problem will be where the signal stops.
Apr 26, 2012 | Roland CUBE Street Amp Combo
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
The unit input voltage is 110 volt and was plugged into 220v outlet. . the input winding is now busted. . i was hoping to know the secondary voltage of the transformer. . i was planning to replace the...
The winding is center tapped. It generates +/-24.5 volts DC. Based on it being a capacitor input filter, we need a peak voltage about 1 volt higher to account for the droop of the capacitor and the .7 volt drop of one silicon diode...
Since we need 25.5 volts peak then we need that divided by 1.414 RMS out of ONE side of the center=tapped secondary... So our secondary voltage is 18 volts either side of center.
You will need a 36 volt center-tapped secondary. Here is one that would work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=162J36-ND
This has two 18 volt windings that you would connect in series and a dual primary you can set for either 120 or 240 input. About $19 US.
Dec 29, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
I like the sound of my practise amp but it's not powerful enough can i connect it to a larger amp without getting feedback/distortion?
you can use the record outputs to run the signal into a stereo receiver without problems, though it would likely sound better with a shure sm57 microphone hooked up to a mixing board or other instrument amp.
the record output should be PERFECTLY balanced to hook up to a consumer-level stereo reciever with NO distortion; however, this record output might be too loud for another instrument amplifier or a mixing board; hence, the microphone in the latter situation.
short answer- "yes, but..."
Nov 26, 2010 | Roland Cube-20x (20w 8" Modeling Guitar...
HI My Rowland Kc60 suddenly has no power. I presume it is shorted out...can I replace the fuse myself, and if so - where and what fuse do I buy and how do I access it on the amp?
Here is a link to the manual:http://lib.roland.co.jp/support/en/manuals/res/1811247/KC-60_e2.pdf Page 9 states that there is a protection circuit built into the power supply. Follow the directions for turning the power on in the manual. If the amp doesn't power up you will have to have it serviced by a qualified Roland tech as there is likely to be some damaged circuitry that won't be repairable without the schematic, parts and safe repair procedures.
Oct 18, 2010 | Roland Kc60
Roland Cube-20x (20w 8" Modeling Guitar Amp) Logo
607 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
