Question about Tamron Cameras
Hi!! The autofocus on my Tamron 79-300 for my nikon d90 dosn't work anymore. Can I fix it?? Is there any solution? Thank you, Lise gagnon
  • 3 Answers
As with almost all camera equipment and lenses I recommend that you do not, under any circumstances try to repair them yourself. Photographic equipment is very delicate and you could just make the problem worse.
The most comprehensive solution would be to contact Tamron itself and send it in for repair. If your product is under warranty you may only have to pay the shipping fees.
You can find Tamron's contact information here:
http://www.tamron-usa.com/contact/default.asp
I hope this information was useful.
Please let me know when/if you get this problem solved.
Posted on Mar 22, 2011
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
Dec 05, 2015 | Nikon DSLR D90 Digital Camera
Is Tamron AF80-210 compatible with Nikon D3000?
This is the tripods and monopods forum, perhaps you would have more luck posting in the camera lenses forum.
Hope this helps
Sep 11, 2014 | Nikon D40 D40X D60 D80 D90 D3000 D5000 &...
Does tamron 80-210mm work for Nikon d90
Tamron makes their lenses with a variety of lens mounts. If your lens has a Nikon mount then it will mount onto the D90.
Oct 22, 2013 | Tamron 80-210mm f/4.5-5.6 Lens
Tamron 14mm 2.8 does not work on d90
This lens is compatible with your Nikon D90 according to this site:
http://lenshero.com/lens/Tamron-14mm-f2.8-IF-Nikon-f-lens
Your complaint "does not work" is rather broad, so I don't know what specific kind of problem(s) your having with it.
If you continue to have issues with it, make sure other lenses work on your D90 to eliminate the body as the source of the problem. Consider performing a 2 button reset on the D90 (and resetting any other customized settings to defaults) and try again. If it still "doesn't work" then contact Tamron to evaluate the lens for possible repair.
Jan 05, 2012 | Tamron Super Wide Angle SP AF 14mm f/2.8...
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
Autofocus stops after heavy usage
Maybe cleaning the gold coloured contacts on the back of the lens and the ones in the camera may help. Worth a try!
May 12, 2010 | Tamron 18-200mm f/3.5-6.3 for Nikon
D90 Nikon autofocus problems
Try a reset (hold down both buttons with green dots next to them) and see if that helps.
Also try cleaning the contacts on the lens itself (light rub with a pencil eraser usually works well).
Jul 30, 2009 | Nikon D90 Digital Camera with 18-105mm...
D90 won't autofocus at distance
Mine seems fine. The only other thing I would think to check is the focus lock is off and the focus area setting.
Apr 28, 2009 | Nikon D90 Digital Camera with 18-105mm...
Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
Jan 15, 2009 | Tamron AF 28-75mm f/2.8 XR Di Autofocus...
Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Apr 19, 2008 | Tamron 28-300 MM XR AF F/3.5-6.3 LD ASP...
Cameras Logo
304 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
