Question about Jetway Mini-TOP HBJC600C99-52W-BW Intel Atom D525 CPU NM10 Next-Generation NVIDIA ION with dedicated... (HBJC600C9952WBW) Barebone
Hello, Is it possible to reset the BIOS without removing the battery? The battery is on the other side of the motherboard.
    Scholar:
  • 109 Answers
If you have attempted to change something in your BIOS so you cannot alter or change any settings because the computer won't boot up properly, unless you have a CMOS reset button on your motherboard the only other way if you can't get into BIOS is to remove the CMOS battery, the CMOS battery is never on the otherside of the motherboard because all the connectors are always on one side of a motherboard
the CMOS battery is a silver flat battery, much like a thing watch battery, remove this battery for 15 seconds so there is no residual power left in the motherboard and then reinsert and reboot your computer
if you can get into BIOS there should be a restore to factory defaults settings in there somewhere.
Posted on Mar 20, 2011
  • Joe Cavanagh
    Joe Cavanagh Nov 19, 2011
    I actually own that model, and the battery is indeed on the other side of the board. I've had to remove it myself today due to a failed overclock. Unfortunately for the OP, there is no jumper on top and you most remove the board from the case to get at the battery. There are four silver screws which must be undone to release the board, and two more black screws holding the front plate in place.
I forget my password bios
To remove the BIOS password all you need to do is reset the BIOS.
To reset the bios all you need to do is open the side panel of the CPU unit and you shall find a electronic battery on the motherboard. This is the CMOS battery. Press on the clip to remove the battery from its slot and wait for a minute. switch on the PC without the battery and switch off after 30 secs. now reconnect the battery and your BIOS reset is done.
I think the issue should get resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote for best answer.
Nov 29, 2012 | Medion MD-40954 Notebook
Tip
Resetting BIOS password
If you have loast the password, to reset the BIOS password you need to remove temporarily the CMOS battery , so to reset BIOS settings.
Some model may be using NV Ram, in that case removing the battery is not enough.
The battery is located on the lower side on the motherboard.
On many DELL models the battery can be accessed from the side of DVD slot, battery slot, or RAM slot, without disassemblying the laptop.
On some model you may need complete disassembly (eg. Dell Le series).
The battery usually looks like a couple of coin batteries wrapped in plastic and connected to motherboard by a two wires connector.
Before disassemblying or removing covers, always unplug adapter and remove battery.
Several Dell Laptop can be set to use NV Ram to store the password.
In this case the problem cannot be solved removing primary battery, then accessing and removing CMOS battery for few minutes.
If you still cannot reset you have two way out.
Disassemble completely and access the NVRAM microswitch, or contact Dell and get master password.
You can also try one of this standard Dell factory CMOS password:
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
on Sep 11, 2009 | Dell Inspiron 8500 Notebook
Tip
How to reset BIOS password on a laptop.
On a Laptop often you have to disassemble the computer to remove the battery or jump the CMOS reset.
On some laptop, like many Dells, and thinkpads the battery can be accessed from one of the slots at the bottom, and it is located deep at one side of the slot.
More commonly battery is located on lower side of the motherboard, and to access it you will have to remove the motherboard.
Better getting schematics before disassembling the laptop.
Do not disassemble the laptop unless you have done this operation several times before, and you have practice.
Before disassemblying remove battery and unplug the AC adapter.
Do not short any pins unless you are sure that you are jumping the CMOS reset pins, even without main laptop battery you can still damage components touching here and there.
The best way to erase CMOS is removing the laptop battery for one minute, thn pputting it back.
This will reset CMOS to factory and erase BIOS settings.
on Jul 18, 2009 | Toshiba Satellite P105-S6227 Notebook
BIOS resets after unpluging PC out of a power grid?
Hello here is the homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX/#download
Try to download a manual by selecting your windows system.
Open the manual folder and hit global for download.
Unzip the file and you need adobe reader to read content.
First of all when removing the cmos battery the bios resets to factory settings.
You need to setup the boot settings and the clock and save it when you leave the bios (read the manual how you do this)
The cmos battery (C2032) must have the volt reading 3,3 volts and the + shiny side facing you:
Try removing the battery and clean the contact points with isopropylalcohol and a ball pin.
Take care not to harm the mainboard.
And take antistatic precautions.
Good luck
Nov 06, 2012 | ASUS P5GC-MX Motherboard
To reset my bios password
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Jan 23, 2011 | Acer Aspire 4315-2963 Notebook
Lenovo n500 forgot bios password
Hello, If you forgot your BIOS password,do not worry, you can reset your system back without requesting a BIOS password,Simply unscrew your laptop and get the motherboard of your laptop, locate the CMOS battery on the motherboard and remove for sometime for the battery to discharge say 4-10minutes,or better still if you can locate the jumpers for the BIOS and reset it,the BIOS password will be removed.It is the battery that keeps the BIOS chip alive by suppling it power,if power is not supplied to this chip,then the information on it will be lost. So, remove the battery for some minutes or reset your BIOS jumper on the motherboard WISH YOU THE BEST.
Nov 22, 2010 | Lenovo 3000 N500 Notebook
I have lost the BIOS password for my HP Elitebook 8540w. I can boot the machine and use it fine, but I can not get into the BIOS to make changes without the Administrator password. Is there a way for...
Hello, friend first will you start your pc in safe mode here will you get two account and will go another account and here will you remove the adminstrator passward without giving adminstrator passward. Please open your cpu in motherboard there is one mini cell is attached and it remove half and hour and then attached the cell in motherboard and then start your pc it will be unlock your bios passward.
Nov 08, 2010 | Computers & Internet
How to reset Asus PC-DL Deluxe BIOS
Remove the Lithium Flat Battery from the motherboard, then start the machine. Let it run for about 5-10 seconds and then turn it off and put the battery back in.
Some motherboards when you try to power it up without the battery, will not turn on. Press the power button 2-3 times and then place the battery back in and it should achieve the same results.
Dec 11, 2008 | ASUS PC-DL Deluxe Motherboard
Remove bios password
There are lots of tools/software available to reset bios password. Just google for "reset bios password" and you will find one of them, else just open your back side of your notebook. Open the screws and remove the bios battery (a circular shaped sitll battery). If possible change the battery with a new one or keep that battery out of laptop for some time. Now start notebook without the battery and shut down.Then reinsert the battery to laptop and start again. The password should be resetted by this process.
Feb 17, 2008 | Computers & Internet
Bios password
usually you can reset the password by taking out the battery and removing the AC adapter, then either pulling out the small watch sized battery on the motherboard and leave it off for a few minutes or move a jumper on the motherboard to reset the bios. If that isn't possible or doesn't work there is a list of backdoor passwords available here. http://saptha.com/blog/?p=32
Jul 24, 2007 | Panasonic Toughbook 47 Notebook
Jetway Mini-TOP HBJC600C99-52W-BW Intel Atom D525 CPU NM10 Next-Generation NVIDIA ION with dedicated... (HBJC600C9952WBW) Barebone Logo
793 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
