Question about Acer Computers & Internet
Please help....I have emachine D725...it won't start up..after the battery had drained and the usb was removed. the power button lit for a second and off again...the cd rom light up and then it has a ticking sound. the fan turns on for a second too. thanks a lot!
  • flishp_adz Mar 22, 2011
    about how many hours should I charged it up? the power button blinks then turns off gain then start again and so on
  • 23 Answers
Your laptop is completely out of juice. Please recharge it and it should work properly again.
Posted on Mar 20, 2011
How to reset bios password emachines d735 series?
I think you mean D725, not D735. I don't think that there is an eMachine D735 model.
The D725 series is a laptop.
Unfortunately, there is no easy solution.
You will need to open the laptop, if you know how to do the reset.
First disconnect your machine from power; this is an important step (otherwise the next step won't work); then open the laptop.
Be very careful not to cause damage with static electricity from your body.
After you open it, remove the CMOS battery for 20 to 30 minutes.
That will make the motherboard forget all the CMOS settings.
Reinstall the battery and try to boot-up.
There used to be a software utility toolkit to reset the BIOS password, but it has now disappeared from the Internet because it could easily be used for illegal purposes.
I hope this helps a little bit.
Mar 02, 2015 | eMachines Computers & Internet
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Please help me with my emachines d725, the problem is the battery don't charge at all, it indicate below the screen (plug in, not charging)..
It sounds like the battery is faulty. If the battery is under 1 year old it should be under warrantee still and you should be able to get it replaced by emachines. If it is over 1 year old you will need to buy a replacement.
Thanks
May 05, 2011 | E-Machines Computers & Internet
My web cam stopped working once i had my computer reprogrammed.its an acer emachines D725
Install the correct webcam drivers version for your laptop OS.
Acer emachines D725 Drivers download @ http://support.gateway.com/us/en/emac/product/default.aspx?tab=2&modelId=1323
Hope it helps.
Mar 24, 2011 | Computers & Internet
My emachine D725 series wont start up after the battery was drained and usb was removed. The power button lit up for a second, cd rom light up too then turns off after few seconds and turns on again..the...
Flishp,
Try running the laptop plugged into power, but without the battery. If this works, try putting the battery back into the laptop; if it continues to work, let the battery charge over night and see if you can run the laptop from the battery. If when you plug the battery in the laptop turns off, you need a replacement battery.
Please let me know if you have any more questions.
Thank you.
Mar 22, 2011 | eMachines Computers & Internet
I have emachine D725 series. the screen turns black and when you press the power button it will just light for a second then off again...it also have this click sound. what will I do to solve this problem?
It may be trying to go into the sleep mode. You can control this by going to the control panel and clicking on the power options. It also could be the power supply going bad
Mar 19, 2011 | E-Machines Computers & Internet
Is emachine D725 has built in microphone???
Ye s the past eleven years they all do have a mic installed. Look for a very small hole surrounding the keyboard for it will be inside there
Jun 30, 2010 | Acer eMachines 520-2890 Notebook
Does not turn on..!
ur battery may be drained off remove ur battery and switch it to ac power and start again . if its ok insert battery and charge it
Dec 03, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
