Question about D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601
My d-link router name no longer appears in my wireless networks list - I can not find it to connect to the internet wirelessly
  • Christine Neale Aug 07, 2012
    Thanks for the great reply :)
    Scholar:
  • 50 Answers
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. My d-link router name no - cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during dataMy d-link router name no - cdekatrr_3.png cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
Posted on Mar 20, 2011
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
How to get my SSID?
Hello there,
The SSID is the Network name. You have to login to your Wireless router to get it.
Mar 15, 2011 | Buffalo Technology WHR-G54S Wireless...
I want to use my d-link router with my new acer laptop but cant connect to the router. Windows says it is a router connection problem. It can locate the router just wont allow me to connect.
1.In Control Panel, click Network and Internet Connections, and then click Network Connections.
2.Right-click the Wireless Network Connection, and then click Properties.
3.On the Wireless Networks tab click Add.
4.In the Wireless network properties dialog box, enter the SSID "(Name of the connection) ex. dlink1234" you configured for your wireless gateway
5.Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway. (WPA-TSK, WPA2-TSK, WPA-AES and WPA2-AES)
6.Click OK and your home network will be added to the list of preferred networks.
if you have a firewall in your laptop try to disable it. example Eset Security antivirus Firewall. Disable the Firewall.
Aug 25, 2010 | D-Link (DI-784) Wireless Router
Can't Reconnect to Secure Wireless Network
there is a problem with your WEP key, means the password which is used to enter your router or network. simply delete the network from the network list and connect to the network again and insert the correct shared key.
May 03, 2010 | 2wire 2700HG-B Router (2700HGB)
How do i establish a wireless connection with my router?
I would start by reading the manual
please download the manual, unzip and follow the procedure to set up your router.
now your question is a simple question yet a complex one to detail here but basically what you do is this
what you need
1.laptop or desktop equipped with a wireless network card. Yo can't stablish a wireless connection if your computer does not have this key component.
2. set up your router so that is whithin range. meaning that your router name should come up in the list of wireless networks detected by your wireless network card in your computer, the signal should be strong enough so you can connect to your router wirelessly.
what you do in a nutshell is this.
1. usually routers come ready to be used out of the box, so if you are not concern about someone else using your router to connect to internet you can just
1. connect your router as follows
a. plug your wan cable coming from your modem to the wan port on your router (that's the cable that has the internet signal).
b. power your router.
2. in your pc, open the wireless network manager (the one installed with the cd that comes with your router or the one that windows has, either one should work) and look for the wireless networks being broadcasted, there is a list and your router by default should broadcast its name "d-link". since the d-link router is the one in your house it should be the one that says "d-link" with the highest signal in the list.
3. double click on that d-link router and you should be connected.
important: in the manual there are instructions to change the default name of your router which is always a good idea. the techincal name for your router is called the SSID, that's the name of your router and by default that name is "d-link" on dlink routers.
if you are concern about someone else (neighbors, war drivers) using your router you may also need to set up a password (psk key or passphrase) and encryption (wep, wpa, wpa2), I suggest you set wpa2 as it's the strongest encryption and will make sure that if signals are picked up by a neighbor or a war driver or hacker your info remains private. your manual should walk you through the process.
as you read your manual feel free to ask more questions and I will follow up with you!
I hope this gives you a good idea on how to start
Apr 19, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Acer with Windows Vista does not connect to Internet
You're laptop needs to have a profile for the router. Go to Network and Sharing Center, Manage Wireless Networks. Please remove all the listed networks there. Now click on Add, then Add a Network in Range of this Computer. Select the wireless name of your router and connect. If it asks for a network key, please type your wireless security key then connect. That should do it.
Dec 19, 2008 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Connection problems
Unless you have a wireless router/access point and a wireless card in your computer, you will need to use the ethernet cable to connect to the internet.
If you do have a wireless router/access point to connect to and a wireless-capable computer, try sticking a pen or the end of a paperclip into a hole on the router marked "Reset" (it might also be unmarked). Hold that button for 30 seconds.
Your router should now be reset to factory defaults. You can now connect wirelessly by choosing the name of your router's manufacturer from the list of available networks. To do that:
Windows XP
  1. Right-click on "My Network Places".
  2. Choose "Properties".
  3. Right-click on "Wireless Network Connection".
  4. Choose "View Available Wireless Networks".
  5. Choose your manufacturer's name from the list that appears.
Windows Vista
  1. Click on the network icon in the lower right of your screen (two computers, one behind another).
  2. Click "Connect to a Network" (it also might be labeled "Connect or Disconnect").
  3. Choose your router manufacturer's name from the list that appears.
Mac OS X
  1. Click on the AirPort menu in the upper right corner (it looks like four "("s on their side).
  2. Choose your router manufacturer's name from the list that appears.
Oct 06, 2008 | Computers & Internet
Having trouble staying connected to the internet
Thank you.
First, make sure that the wireless switch on your computer is on.
Then try following these steps:
1) Go to Start and click on Connect to.
2) Connect to a network window will appear. This window will show all available connections, which are dial-up, VPN and wireless connections, but your focus is on wireless connections. Scroll down the list and select the wireless network that you wish to connect, finally click the Connect button.
Note: If the network you choose is security-enabled network, means require authentication. One of the following will occur:
- If the network key is automatically provided by your network or system administrator (that is, the network supports IEEE 802.1x), the connection will be made automatically.
- If the network key is not automatically provided, type in the key. The key can be WEP/WPA/WPA2 encryption key.
Note: If you see the network is tagged as unnamed network, that is non-broadcast network with hidden SSID. When you make connection to this type of network, you will be prompted to type the wireless network name (SSID).
3) Once you connected to wireless network, the connection will show connected.
Then, you can go online. :)
Apr 29, 2008 | 2wire 2700HG-B Router (2700HGB)
I cannot creat a wireless network
What OS are you running? If XP:
There are two ways to configure your wireless router: using Windows Connect Now and manually.
• If you don't have a router that supports Windows Connect Now, you need to manually configure your router:
1.
Using the network cable that came with your wireless router, temporarily connect your computer to one of the wired network ports on your wireless router (any port that isnt labeled Internet, WAN, or WLAN).
2.
Turn your computer on; it will automatically connect to your router.
3.
Open Microsoft Internet Explorer and type in the address to configure your router, as described in your router's instruction manual.
4.
Create a password if a prompt appears. The address and password you use will vary depending on what type of router you have, so refer to the instructions included with your router.
Here is the general login user and passwords
3Com
http://192.168.1.1
admin
Admin
D-Link
http://192.168.0.1
admin
(leave blank)
Linksys
http://192.168.1.1
admin
Admin
Netgear
http://192.168.0.1
admin
password
Internet Explorer will show your router's configuration page. Most of the default settings should be fine, but you should configure three items:
Set your wireless network name (known as the SSID) to something unique that does not identify your name or address.
Enable Wi-Fi Protected Access 2 (WPA2) encryption to help prevent uninvited guests from connecting to your wireless network.
Note: We don't recommend using WEP. WPA-2 is more secure. If you try WPA-2 and it doesn’t work, we recommend that you upgrade your network adapter to one that works with WPA-2.
Set your administrative password to prevent others from configuring your router.
The exact steps you follow will vary depending on the type of router you have. After each configuration setting (SSID, WEP, and administrative password), be sure you click Save Settings, Apply, or OK to save your changes.
Note: The pictures in this section show Linksys wireless equipment. Equipment from other manufacturers will vary in appearance. For example, to save your settings in Linksys, you click Save Settings. Other equipment may have a different display, and you may have to click Apply or OK.
SSID or naming your networkA service set identifier, or SSID, identifies your network. Choose a unique name that you're confident none of your neighbors will use, but don't specify your name or your address. This is not a security tool, so you don't need to make the SSID complex.
Help prevent uninvited guests from connecting to your wireless network. To learn how, read Implement WPA2-Personal wireless security on a Windows XP SP2-based computer.
Administrative passwordThe last configuration change you should make is to the administrative password. Just like any other password, the administrative password should not be a word you can find in the dictionary, and it should be a combination of letters, numbers, and symbols. Be sure you can remember this password, because you'll need it if you ever have to change your router's settings.
Connect your computers and devicesIf your computer does not have wireless network support built in, you can install a wired or a wireless network adapter. Windows XP will automatically detect the new adapter and might prompt you to insert the CD that came with it. The on-screen instructions will guide you through the configuration process.
Windows XP Service Pack 2 (SP2) is not required for wireless networking, but it does make setting one up much easier. SP2 also helps protect you against viruses, worms, and other Internet intruders. To install SP2, visit Microsoft Update. The steps below apply only if you're using SP2. Windows XP will show an icon with a notification that says it has found wireless networks.
To connect your computer to your wireless network
1.
Right-click the wireless network icon in the lower right corner of your screen, and then click View Available Wireless Networks
2.
The Wireless Network Connection window appears and displays your wireless network listed with the SSID you chose. If you don't see your network, click Refresh network list in the upper left corner. Click your network, and then click Connect in the lower right corner.
3. Windows XP prompts you to enter a key. Type the encryption key that you wrote down earlier in both the Network key and Confirm network key boxes, and then click Connect.
Windows XP will show its progress as it connects to your network. If the Wireless Network Connection window continues to show Acquiring Network Address, you may have mistyped the encryption key—click Cancel and return to step 3.
After you're connected, you can close the Wireless Network Connection window. Now you're ready to browse the Web wirelessly. You can also create a wireless network in your home that connects your computers, printers, cameras, games, and other accessories for easy access and enjoyment.
Apr 21, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link Wireless N 150 Home Router 4Port Switch 80211nbased 150Mbps DIR601 Logo
152 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
