Question about Dryers
I have a maytage front load washer,it is stuck in control lock ,and i can't get it to do anything. the model#is mfw9800tq0. washer
  • dnickboe Aug 31, 2008
    Yes we have a maytag 9800 and at times when the cycle is complete and it says complete in the control colum, all the cycle lights are still on and the door won't open for a minute or two untill you hear the door release
Med9600sq0 model #
as per maytag website=hold the "cycle signal button for 3 seconds" and it w i l l unlock. I just did it!!!
Posted on Aug 26, 2008
Washer lock
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance. This can usually be reset and usually is not an indication of an actual problem with the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Jun 07, 2010 | Maytag EPIC MFW9700S Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Washer control is locked
The following link explains how to correct a Control Lock problem for your washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
Aug 14, 2009 | Maytag EPIC MFW9700S Front Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
My Maytag front end loading washer is stuck locked
Open the detergen/bleach diospenser cover and there is a tab there that you can pull to open the door. You will likely need to replace the wax motor and control board.
Apr 07, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washer is stuck on "control locked" how does one unlock it?
To unlock your washer press, washer/rinse temp and spin speed pads at the same time for three seconds, the control lock light will go out, hope this helped.
Mar 30, 2009 | Maytag Neptune MAH6700A Front Load Washer
Dryers Logo
197 people viewed this question
Top Dryers Experts
