I have a DeLonghi electric1.5 kw oil heater Type KH 509715 SN 63314 which I bought on 24.12.06. at B & Q , it has always worked perfectly. Yesterday when I swithced it on the lights on the switch flickered & went out & the heater did not heat up. I have tried a new 13 amp fuse but nothing has happened . Please could you advise me & is the heater still under guarantee ? Thankyou
koolbreezes
  • 540 Answers
SOURCE: 10 kw heat with 2 speed fan
Checkout GOODMAN ELECTRIC FURNACES . website.
Posted on Sep 04, 2008
  • 66 Answers
SOURCE: AC, but no heat
The clicking noise appears to be the igniter. Since it is not getting gas for some reason it will not operate and will shut down. This could be due to the burners being dirty or it could be a bad gas valve or it could be in the electronic mudule. Make sure there is gas coming into the home to the gas valve.Since you hear the igniter operating , for the time being we will assume it is ok. Clean the burners with a wire brush. Make sure they are clean. When reinstalling the burner. Make sure the igniter is directly over one of the burners in the path that the gas will take. This is important. Before attempting any repairs make sure you understand what to do and what not to do. Gas furnaces can be vary dangerous. If this is something you are not absolutely sure you can do. Get a qualified service man to repair and service the unit.You can get a qualified service man right here on this site for your area. I hope I have been of some help to you.
Posted on Nov 19, 2008
billyvangogh
  • 108 Answers
SOURCE: Goodman Air handler blowing fuse if switch outside unit not runni
Sounds like your compressor in your heat pump is siezed . You can try a "Hard Start" Capacitor...which basically gives your compressor a kickstart and works 95% of the time when compressors get older....It's hooked up in parallel with the existing Capacitor...if you're not familiar with Electrical etc I would call an expert and mention what I said . If this doesn't work you will likely need a new Compressor/Unit . You could also have a short to ground in the heat pump side....likely the compressor is the problem however the original Capacitor could also be the problem
Posted on Oct 27, 2009
SOURCE: Our Sharp inverter air conditioner
Did either of you solve your problem as I have the same problem with my Sharp unit
Posted on Feb 18, 2010
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
Need replacement caster for DeLonghi oil heater mod# EW6507L
Hi, I found something on amazon. Take a look here: Amazon com delonghi caster. I hope I have helped. cheers
Jan 18, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Actual output on settings
MODEL DELONGHI TRD0820ER 2KW OIL FILLED RADIATOR
YOU HAVE THREE SETTINGS
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Split System Air Conditioner Model sn:QC136AUP(QC136EXU)107034-73 What six=ze is it ? what Kw?
Enter the name of the unit into your browser. It will ask for a model #. Enter that. All the info you need should be displayed. (I can tell by the model# your unit is 3 ton. Rule of thumb; 10 amps/ton Therefore 6.2 KW)
Ray
Nov 11, 2008 | DeLonghi Heating & Cooling
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Daily cost to operate
electric is billed at so many cents per kilowatt hour. a kilowatt hour is 1000 watts per hour. if your heater is rated at 3000 watts, running it for one hour will consume 3 kilowatts of energy at whatever your utility charges per kilowatt. if the amount on your bill is .026 per Kw it'll be 2.6 cents per hour.
Nov 19, 2007 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
