Washing machine fills with water but drum won't spin and water won't drain. Checked carbon brushes & cleaned out filter, still no joy.
  • Washing Mach... Master
  • 1,527 Answers
Hello try the module board this control the motor speed it sit at the back of the washer usually as a load of wires coming of it hope it helps
regards
shaun
Posted on Mar 20, 2011
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 12, 2014 | Beko Wm & Wma Models Washing Machine Motor...
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
My beko wm7247w wont spin
Hi Tina if your beko wm7247w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 26, 2013 | Washing Machines
My siemens xlm 1400 wont fill with water so when it spins clothes are not cleaned.It won't drain properly either. It sees to only fill 10% of the water required. I have checked the pipes/hoses - a
I would take the back off and look for a small 5mm pipe leading upwards from the base of the drum and take it off and blow gently into it you should hear a click and one when you release the air if so then the place where you took the pipe from is blocked clean it out with a pipe cleaner or metal rod and replace the pipe as sometimes this pipe gets blocked with soap goo preventing the water sensor from doing its job eric
Jan 01, 2018 | Washing Machines
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Beko washing machine wma 1512S will not spin.
hi
try changing the carbon brushes in the motor
Apr 29, 2009 | Washing Machines
Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Sep 23, 2008 | Washing Machines
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
