Question about Watches
How do I set the time and date of puma LED Watch (Digital)?
SOURCE: Adidas watch
Troubles you to help the solution to look for adidas the adx156 instruction for use, thanks!
Posted on Feb 27, 2008
SOURCE: timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Posted on Jun 02, 2008
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Posted on Dec 23, 2008
SOURCE: setting the time for the puma sirius
Finally got it! Take a sharp ball-point pen and push it into the hole/bitton on the lower left side of the face. When I first tried it a zillion times, I could not get anything to happen. Then I handed it to my husband, and he said that you have to push it in with a little bit of force (more than mine, anyway) and the "setup" mode appeared. After that first time, it doesn't have to be pushed as hard!
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: i have Puma-Time touch screen
Dont have that particular watch, but see if this works.
Setting the time on the PU910222003 Puma ladies watch.
The process may be less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Posted on Mar 07, 2011
Star Wars rebels led watch how to set time and date
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
Mar 14, 2015 | Watches
How to set time in puma digital watvh
https://brand.puma.com/time/support
www.youtube.com/watch?v=PxcHizUdJk8
Jun 17, 2014 | Puma PL1050
Intercrew LED watch, model ic3905. How do I set time and date?
Setting intercrew led time and date - Fixya
www.fixya.com/support/t14276175-setting_intercrew_led_time_date
Sep 8, 2012 - setting intercrew led time and date no instructions to set time and date on LED Watch by INTERCREW - Watches question.
Intercrew LED - YouTube
? 1:57
https://www.youtube.com/watch?v=bR9oGWDTwxs
Jan 25, 2012 - Uploaded by CoolWatchDanmark
Review af et af vores meget popul?re LED-ure. Intercrew LED. ... ????????
Dec 24, 2013 | Watches
I cannot figure out how to set the time on my Puma watch.
mcdevito75 here, You can try www.puma.com They have an overseas number but also the option to find a Puma retailer in your area.
Jul 13, 2010 | Puma Active Collection Fluctuation...
PUMA FLUX watch - reset time
Press and hold the button on the upper left until it displays "HOLD" then wait 'til the light goes out, you'll see the hour-digit blinking, set the hour you want, then for the minutes, press the lower left button. Press and hold the upper left button to set the desired time.
May 02, 2010 | Puma Digital Alarm Chromograph...
HOW DO YOU SET THE TIME ON THIS WATCH
May I get the make and model # of the watch to help you more.
Mar 24, 2010 | Puma Flow Digital Watch PU90005A0298H37
Setting the time for the puma sirius
Aug 04, 2008 | Puma Bracelets PU103SLA0051500 Watch
Watches Logo
779 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
