FixYa.com
Tags:
Tatung CM 14UHE  14 in.CRT Conventional Monitor
Startx fails
By Jimmy NY - usenet poster
I have just completed installing rh7.0.  When I try to "startx" it goes
along loading things and dies with the message:
Fatal server error:
Caught signal 11.  Server aborting
The last message prior to the error is:
(II) TRIDENT: driver for Trident Chipsets: tva8900d,
cyber9320,cyber9388,
            (more drivers listed)
                        cyberbladei7,
cyberbladei7d,cyberbladei1,cyb­erbladei1d
Fatal server error:
Can anyone explain how I can fix this error?
The monitor is a Tatung CM-14UHE
The video card is a trident VGA9000 w/ 512k memory
I had this same monitor and card working on rh v5.2
An unrelated question.  How can I tell what other RPMs are needed, when
I load a particular package. I am trying to do this from a command line?
Please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
Helpful (85)
Rogers
Rogers - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I'd run Xconfgurator again..  I've had problems with that card on a PC
I've got here...  /var/log/X.log will tell you more about what it is
trying to do such as probing the card and looking for acceptable
resolutions...
As far as the RPMS go, when you try rpm -ivh thisfile.i386.rpm
it should say what is needed.  Go to RPMfind and look for those files as
part of another package.   the developers web site will also have the
package requirements and usually they links to those packages...
In article <3AC4F231.DFE54 @ix.netcom.com>, "Bob"
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
When you install/upgrage an RPM do:
        #rpm -Uvh foo.rpm
the 'v' is for verbose so RPM will print a list of packages it needs.
The 'h' prints hash marks '#' that show install progress.
Can you Help with these Monitors problems?
Monitors
monitor flashing from power...
monitor flashing from power... Answer This...
Monitors
MAG Innovation Moniter Model...
I have a four year old moniter... Answer This...
Monitors
lock unlock
hi, I'm having a little problem... Answer This...
Monitors
changing source on daenyx tv
when I try to change from av to... Answer This...
Monitors
Samsung LCD Monitor Won't Stay...
My SyncMaster 171v suddenly... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
