Question about Mackie SWA1501 Subwoofer
SOURCE: Signal light stays on, no sound output
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
Posted on Sep 16, 2008
SOURCE: I have a pair of
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Posted on Dec 04, 2008
SOURCE: replaceing internal fuse to mackie active sub woofer swa 1501
Hi There, you need to check the 3 fuses that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these by pulling out the burnt out fuse and replace with a new fuse and hey presto you should be back up and running. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Also the offer a service of swapping them over for you if you really don't want to do it yourself. Hope this helps. Grant (from www.LondonSpeakerHire.com)
Posted on Mar 24, 2009
SOURCE: Mackie srm450 not making any sound at all
It sounds like the thermostat didn't shut the speakers down before they were damaged. There is probably a very fine wire leading to the speaker coils which is burned/broken. Fixing this broken connection my solve the problem unless the coil itself is damaged.
Another possibility is that the crossover circuitry in the speaker cabinet is damaged from overheating.
Sounds like you need a service tech to look at the bad speaker, unless you want to tackle the job.
Posted on Apr 22, 2009
SOURCE: Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Posted on Jul 31, 2009
Oct 06, 2014 | Mackie SWA1501 Subwoofer
Jun 17, 2014 | Mackie SWA1501 Subwoofer
Feb 18, 2012 | Mackie SWA1501 Subwoofer
Sep 20, 2010 | Mackie SWA1501 Subwoofer
Mar 12, 2010 | Mackie SWA1501 Subwoofer
Nov 26, 2009 | Mackie SWA1501 Subwoofer
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Sep 16, 2008 | Mackie SWA1801 Subwoofer
Jan 13, 2014 | Mackie SWA1501 Subwoofer
Nov 01, 2013 | Mackie SWA1501 Subwoofer
