Question about Oregon Cutting Systems Chain Saw Cutting Chains, 16"
Fuel and two stroke mix pls oil type for chain pls
Fuel and two stroke mix pls oil type for chain pls tks rgds ****
  • 45 Answers
For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  • Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Posted on Mar 20, 2011
Oleo mac 925 manual how do i fill this is it seperate oil+petrol or is it a two and one mix
Chainsaws are two strokes, the oil pump on the saw is to pump chain oil to the cutter bar, the fuel in the tank should be a 25-1 fuel two stroke oil mix.
Oct 06, 2011 | Garden
What is the fuel & oil mix for a chain saw
Husqvarna chainsaws run at a 50-1 fuel oil mix with Husqvarna two stroke oil, with other two stroke oils they recommend 25-1 fuel oil mix as they do not know the quaility of other manufacturers oil, always try to use Husqvarna oil.
Sep 25, 2011 | Husqvarna Chain Saw 20" Bar
Fuel mix 1.40 or 1:50?
This is usually dependant on the two stroke oil quaility, good quaility two stroke oil from a major chainsaw manufacture will normally be advised to mix at 50.1, always try to buy good two stroke oil, from a chain saw manufacturer, they know the importence of oil quaility on high reving two strokes.
Aug 24, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cant find mix fuel/oil for stihl ms 181
Model MS 181 Engine single-cylinder two-stroke Capacity 31.8cc, 1.94cu.in Bore 38mm, 1.6in Stroke 28mm, 1.1in Ignition Electronic (Breakerless) magneto Spark Plug NGK CMR6H Electrode Gap 0.5mm, 0.02in Carburetor All position diaphragm type with built-in fuel pump Fuel Tank 0.27litre Fuel mixture 50:1 with Stihl two-stroke air-cooled engine oil Catalytic Converter No Chain lubrication Automatic oil pump Oil tank 0.265 litre Weight
(dry, no bar, no chain)
4.3kg (9.5lb)
Jun 22, 2011 | Garden
How engine oil i put?
You mix the petrol with "2 stroke oil" at a ratio of 40:1. Use good quality 2 stroke oil like Husqvarna or Stihl rather than the cheaper ones you get in service stations.
You also need to use Chain Oil which goes in the opening marked Oil. You can get chain oil from any tool hire company or hardware store. It needs to be refilled each time you refill the fuel mix.
Jun 07, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What type oil for chainsaw, both w/gas for fuel and also chain lubrication
You mix 2 stroke oil with the petrol/gas at a rate of 40:1 (40 parts petrol to 1 oil). For longer life use a good quality oil like Husqvarna or Stihl rather than the cheaper types you buy at car service stations.
The oil you use for the chain lubrication is just known as chain oil and can be bought at tool hire outlets.
Mar 29, 2011 | McCulloch Chain Saw Scrench For Homelite...
Does this chainsaw require a mix in the gas?
Yes it certainly does require a fuel oil mix, with good quaility two stroke oil the mix should be 50-1, always buy the best two stroke oil you can, use your local horticultural dealer.
Feb 11, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
What type of oil do you put in the reservoir?
is it 2 stroke? if so 2 stoke oil mixed with petrol regards
Feb 03, 2010 | Ryobi Factory Reconditioned 10-Inch 18...
Oregon Cutting Systems Chain Saw Cutting Chains, 16" Logo
93 people viewed this question
Top Oregon Cutting Systems Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Oregon Cutting Systems Garden Expert? Answer questions, earn points and help others
