I am looking for the pump on my whirlpool washing machine the red light is coming on saying clean the pump but i can't find the pump
    Brigadier General:
  • 6,277 Answers
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 20, 2011
Hi the red service light has come on and wont let me wash please tell me what is wrong with it thank you very much
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out, the red light is telling you to clean that part
Jul 13, 2011 | Whirlpool Washing Machines
The red light 'Clean Pump' on my WFS1071BW washing machine is on. How can I access and clean the pump? Thank you for your response.
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out. hope this helps and please rate me thank you...
Jun 06, 2011 | Whirlpool AWM5125/1 Front Load Washer
Red light saying clean pump...how?
Think the filter is located R/ h side bottom of machine this should come out and be cleaned,put an old towel under here first as water will come out...Good luck
Apr 21, 2011 | Whirlpool Washing Machines
Cannot find the exact machine i have which is WFS1073CD but this one looks similar. Red light is on to say clean pump, where is pump?The book we have is not in english
Your machine should have a lower front panel attached below the door. This would be a full width panel that goes from the floor up to almost the bottom of the door. Unplug the machine. Remove this panel with 3 or 4 screws. The pump is behind this panel, facing forward. The pump has a twist plug clean out. Use a shallow baking pan to catch the small amount of water that will come out of the pump when you open the twist plug. After cleaning the pump, assembly is the reverse of what you just did.
Good luck.
Jan 30, 2011 | Whirlpool AWM6141/1 Front Load Washer
Whirlpool washing machine say clean pump/ modal awo/d 4605 how do i do that?
Unplug the machine.
Remove the bottom front panel.
The pump will be directly in front of you. Twist and pull and the pump filter will come out.
Jan 07, 2010 | Whirlpool Washing Machines
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump red light on Whirlpool WFS1071AW, How do I?
TAKE OUT THE SCREWS ON THE BOTTOM PANEL AND ON THE INSIDE OF THE MACHINE NEXT TO THE PUMP YOU WILL FIND A PIECE OF PLASTIC WITH A SMALL HANDLE, ROUND IN SHAPE, PULL THIS OUT AND CLEAN THE FILTER
Aug 11, 2009 | Whirlpool Washing Machines
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
