Check to make sure your fan is clear and clean and not blocked - blow it clean if necessary with a can of compressed air or a compressor. Elevate the laptop if possible also. A laptop cooler can help as well - it is a tray that has more fans in it.
I would start by cleaning the fan, vents and heatsink. Use a can of compressed air. You may have to open the Laptop to clean thoroughly with the air and a light brush, use ESD protection as well. . Improve air flow from the bottom of the laptop and the side vents, a Laptop Cooler is a option. Hopefully you haven't done damage to vital components due to overheating. Unplug, remove battery, leave battery out, plug in, try to reboot.
Check the machine for dust, and us canned air to move it out. Make sure that your fans spin upon powering on your machine. Fan controllers can be downloaded to help boost fan speed and cool the machine. Make sure you're not placing the laptop on anything preventing airflow, like carpet or blankets.
Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
Sounds like it is overheating. Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it. You also might want to get a laptop cooler.
make sure the cooler fan is getting power test the leads that attach to the cooler make sure the connection is good and not faulty
also you should clean the cpu make sure there is no dust built up on the fins of the cpu
(dust will cause static) to computer overheat and lots of unforseen problems
also you purchase a portable usb laptop cooler pad
hope this helps
I have had this problem, I elected to purshase a cooler.
The cooler is just a device that sits under the laptop and plugs into the USB port.
Some laptops were not designed to be very cool, so they need some help.
You could google laptop cooler of if you have a BestBuy close you can visit them.
I hope that this helps you out.
Thanks for using FixYa.
asnowman
This is caused by the fan and cooling system.
Disassemble your laptop, remove the fan cooler, clean it up, replace the paste on top of your processor, tighten and screw the cooler fan again.
buy your daughters laptop a laptop cooler with built in USB fans i had similiar problems with my wifes hewlett packard compaq cq bought a laptop cooler fixed the problem
(if you replaced the cooling fan why does'nt it run)
hope this helps
