Question about Samsung DLP HL-P5663W 56" TV
Samsung DLP HNL4365WX S-Video Display Quality
Recently the display quality of our Samsung DLP has degraded, but only through the S-Video & RCA ports. I've tried different S-Video cables, and various sources (TiVo, DVD, etc.) and the problem persists with each source and cable. The Component, PC, and DVI inputs produce a very clear excellent images, however our TiVo only has S-Video and RCA outputs so I'm stuck using S-Video.
I'm wondering if the S-Video and RCA potsr use the same circuit board If so, is the board replaceable? Has anyone experienced this?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Upgrade to tivo with Comp. out.
Posted on Aug 03, 2008
My video quality is very poor can I fix this
The quality of the video you play depends on the quality of the video itself. If the resolution of the video you play is low then your tab cannot replace the missing pixels. Try playing high resolution videos.
If you think you're playing high quality videos and yet your tab still doesn't display it in high resolution, then there must be something wrong with either the setup or the device itself. In the later case, I recommend you consult the shop where you bought the tab from.
Hope this helps.
Apr 24, 2011 | Samsung Galaxy Tab Tablet PC
Insufficient video signal
How is the cable box being connected to the DVD recorder?
Feb 14, 2008 | RCA DRC8060N DVD Recorder
The picture is not bright in a light-filled room. Will a change of DLP lamp help? Are there different lamps that will improve picture quality?
Yes.Depend how old is ur DLP tv,the Projection Lamp only a light source,mostly depended on the Light projection Engine itself.Get the original RCA DLP lamp or same lamp model now inside the tv,will help and work best for ur tv.Just don't get generic DLP tvs lamp,it cheaper poorer quality.
Dec 17, 2010 | RCA HD61LPW167 61" HDTV
My HDMI ports went out. Everything else works. Can I repair the HDMI ports myself?
Yes you can replace the HDMI ports yourself following the replacement guidelines of the manufacturer, remember to use the same part that was in the first piece of equipment
Nov 30, 2009 | Samsung 61" 1080p Slim-Depth DLP HDTV
Can't get clear picture on my 50" Samsung DLP
Most of the Analog viewing will be much poorer compared to HD. Since it it a digital product, it is designed to be used with a digital signal. You will get signal degradation if it has to take the analog and convert it to digital to be viewed and there is really nothing that can be done to compensate for it.
Hope this helps,
Skyassoc
Jul 04, 2009 | Samsung DLP HL-P5663W 56" TV
Poor display quality (wallpapers, photos etc) of samsung g600
u should save images as .bmp and than transfer them to your g600, or save them as .jpeg but resolution should be 240x320 or less for good previewing!
Pictures in my photos just zoom in and out and quality is way better!
Or save some of them in mms save and then you can view it in full screen in that sms.
hope it helps a bit..
Nov 21, 2008 | Samsung SGH-G600 Cellular Phone
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
DSC-W55 movie camera video display problem
Your quality setting is probably set to the E-Mail quality. This makes the video low quality and tiny.
Just press the button that you use to delete pictures with the regular screen on and change the image quality.
Jul 07, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
I AM TRYING TO TURN MY JVC TV INTO A MONITOR FORMY LAPTOP BUT I CANT SEEM TO GET THE RIGHT CHANNEL. I KNOW ITS NOTHING TO DO WITH MY LAPTOP SO ITS TO DO WITH THE T.V. I THINK I NEED SOME SORT OF CHANNEL TO...
hi dear
Laptop Multimedia Ports Info
Component Video Out: Connects a TV or HDTV to your notebook so you can view high-quality, high-definition video streaming from the notebook. This three-piece connection (color-coded red, blue, and green) is the best method for sending video from your notebook to an HDTV or anything that receives component video. This connection allows the chrominance (color) and luminance (brightness) portions of a video signal to be processed separately, thus producing higher-quality video than an S-Video connection. S-Video works similarly, but component video improves color accuracy even further by splitting the chrominance signal into two portions.
Composite In/RCA: Connects a gaming console or camcorder to your notebook, for viewing video or playing games on the notebook. Color-coded red, white, and yellow, composite video input uses standard RCA-style jacks to connect your notebook to receive video and audio signals from your TV, VCR, game consoles etc.
TV Tuner/75-Ohm Coaxial: Connects a cable box, TV, or VCR to your notebook, so you can watch and record TV content on the notebook.
Sometimes called an Rf input, a 75-Ohm coaxial cable can carry video and stereo signals simultaneously. RF cable connectors (often called F-type connectors) screw onto the 75-ohm jack, are pushed onto it, or connect via a dongle that vendors usually supply.
S/Pdif/Dolby Ac3 Digital Out: Connects your notebook to speakers or a stereo receiver to play digital audio stored on the notebook. S/PDIF (Sony/Philips Digital Interface) is a standard audio-transfer file format, usually referred to as digital audio. This connection allows the transfer of audio without converting the signal to and from an analog format, which can degrade its quality. If you also have an S/PDIF In port, you can play digital music stored on an MP3 player through your notebook. The headphone jacks found on some notebooks double as S/PDIF Ports.
DVI: Connects a digital projector or LCD panel to your notebook to display in large format either video content or a PowerPoint presentation stored on the notebook. DVI (Digital Visual Interface) is a multipin connection used for passing standard-definition and high-definition digital video signals. It's found on HDTV tuners, a growing number of DVD players, HDTV-ready televisions, and some computer displays. DVI-D is the type of DVI connection found on most home video gear and carries digital-only signals. DVI-I is used with some computer video cards and can pass both digital and analog video signals. Some TVs have DVI-I inputs for greater hookup flexibility. DVI connections transfer video signals in pure digital form, which is especially beneficial if you're using a fixed-pixel display like a plasma, LCD, or DLP TV.
Firewire/ I.Link 400/ 1394: Connects a digital camcorder or external hard drive to transfer (but not display) large files, such as MPEG video, to your notebook. Also known as IEEE 1394, this is an extremely fast (commonly up to 400 megabits per second), two-way digital connection used for plugging in Your DV camera or other peripherals (such as an external hard drive or optical drive) to your notebook. It is used in digital camcorders because it is one of the few connections capable of quickly transferring full-motion video.
S-Video In: Connects a digital camcorder to your notebook to display video stored on the camera on your notebook's screen. Also, if your VCR has an S-Video Out port, you can transfer your VHS tapes to digital format. S-Video inputs use a four-pin jack to receive video signals from camcorders, gaming consoles, TV, or any device that has an S-Video out port. the S in S-Video stands for separate: S-Video connections transmit the chrominance (color) and luminance (brightness) portions of a video signal along different paths, allowing them to be processed separately, though S-Video does not produce as vivid an image as component video. This is a common way to display content from a digital camcorder or any device that has an S-Video Out port. (Firewire also transfers data files from your camcorder to your notebook, but it can't display video in real time on your notebook.)
S-Video Out: Connects a plasma or newer TV to your notebook to display video content streaming from the notebook. The most common way to connect a TV to a notebook, S-Video Out uses a four-pin jack to send signals from your notebook to your TV or anything that accepts S-Video In.
and use Fn+F5 or Fn + F4
to switch your ntbook to tv
oke
Mar 22, 2008 | Computers & Internet
Samsung HL-p4674 RB
Sir, Pull up the on screen menu and make sure the unit is set to display 1080i or 720p instead of 480i. This may be the issue. Good Luck
Jun 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
