Question about Refrigerators
I have problem adjusting the Temperature. The temp is set at REF 05C - 18C. This cannot be changed. I have lost the User Manual. How can I obtain the manual? Pls advise Thank You Lal Ralte
    Genius:
  • 1,157 Answers
Hi lbralte,
Can i ask for the brand, type and model name of your Refrigerator?
Thank you for using FixYa.
Posted on Mar 20, 2011
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Mar 07, 2015 | KitchenAid Ovens
Samsung rs2577sw Refrigerator
if you make the changes on the temp nob doesnt it work.
Jun 20, 2008 | Refrigerators
I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
May 23, 2014 | Liebherr Refrigerators
Cannot adjust temperature
There are two types of Temperature adjuster in a frigs. Manual and electronics.
At the Manual type, there is an adjusting knob to select your choice temperature.
While at the Electronics type. You have to use the User Manual to guide you in setting the proper temp. Most of the time it has a time delay before it execute the programs your encoded.
May 11, 2011 | Refrigerators
How do you set the temperature of the freezer...my freezer freezes at the mid setting on the control dial.
get a thermometer and set the freezer to -18C and a fridge to +5C.
these are the optimum temperatures for keeping food.the internal knobs are for guidance once set,to adjust to seasonal changes.summer to winter.....and for when you refill
Aug 28, 2010 | Magic Chef MCBR440 Compact Refrigerator
HOW DO I SET THE TEMP ON MY REF
Adjust the refrigerator and freezer temperatures with the temperature controls, usually located on the inside of the refrigerated section, some models have the temperature controls on the outside of the doors, accessible when the doors are closed.
Jul 28, 2010 | Samsung RB215LASH
How to use the remote control to set the desired temp
Indoor temperature Operation mode Target temperature
Less than 200C HEATING
(FOR HEAT PUMP TYPE)
FAN 23C
20C~26C DRY 18C
Over 26C COOLING 23C
You will get good results by applying this meter
Jan 07, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Temp lights changing before full wash
your hot water supply might not be getting to the machine.
check the filters in the hot water supply hose.
If the waters not hot enough the hot water light will flash,or you can go into Options adjustment,in your user manual,then adjust you water temperature, its is easy.
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
