Question about Nokia N73 Cellular Phone
My n73 rm132 converted into rm 133 for 3g but dual mode and utms doesnot select. Phone restart and again appear gsm. How can i select umts to use 3g.
5 Suggested Answers
hemantraj
  • 638 Answers
SOURCE: Hi folks, I have a
LG cu500 is the olly model i feel u should buy .it has everything u want.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 27, 2008
  • 42 Answers
SOURCE: video call at nokia E71
this fasility is not avalable in india
Posted on Apr 04, 2009
270rexton
  • 782 Answers
SOURCE: I have Nokia N95-2 8GB H3G UK Its Firmware Version
Hi, on 3 branded devices (Nokia,SE etc) you can't change the band mode. This modification is built in to the hardware to prevent using 2G (GSM) network whom 3 have to pay "roaming" charges. The only way to use GSM mode is to modify the hware. Forum rules doesn't support hacking etc so can't help you here...
Posted on May 12, 2009
  • 75 Answers
SOURCE: BlackBerry Bold 9700
The Bold has ALL of those frequencies- not 1 or the other.
Posted on Dec 22, 2009
Nokia e5 network solution
What you should know is that if you check your phone network settings, it's always on DUAL MODE which means it automatically access Edge and 3G which makes it difficult for the phone to have network on it whenever the area your are has limited network services.
All you have to do is goto Ctrl. Panel (Control Panel) ' Settings ' Scroll down' Click on Phone' Scroll down ' Click on Network ' Now Click on Network Mode ' You will see three types i.e Dual Mode, UMTS(3G), GSM Choose the GSM and immediately you will start having Full network on your phone again, you can follow the same process to switch back to either Dual Mode or UMTS(3G) - See more at: http://www.gistplanet.com/2012/02/solution-to-network-problemissue-on.html#sthash.VWEAxQ3V.dpuf
Mar 02, 2013 | Nokia E Cell Phones
Sir i have n73 mobile, i get the signals on dual mode , and gsm but i can't get signal on umts mode please tell me what is the problem with my mobile
junnyy43,
If you can find your way on your phone on the phone network settings (GSM or 2G/3G) you maybe able to change the setting to UMTS.
Please take note, on some phones, UMTS, 3G, 3.5G, HSDPA may all be the same.
Most often you can only select 2G or 3G, 3G may actually mean UMTS/HSDPA/3G/3.5G.
Just curious, may I know the reason why you want UMTS? Perhapd I understand what you want to do, so I can give a better recommendation.
Aug 21, 2011 | Nokia N73 Cellular Phone
When I send a text, it sends but stays in the outbox and constantly resends the same message, how can I fix this?
For that issue, if you have to dual connectivity selection (GSM and UMTS) make sure to select the dual mode or if you are on UMTS mode or 3G switch it to GSM mode and vise versa.
Please rate! Thanks!
Apr 10, 2011 | Cell Phones
My nokia e63 wont receive calls, what is wrong please?
Go to settings->phone->network and changed the network mode from "dual mode" to "gsm". the other option there is UMTS. and that did the trick. you can always change back to dual as i remember on one of my old Nokia the phone wasn't detecting network and i had to do the reverse (from GSM to UMTS) to get it all good.
some notes:
-Universal Mobile Telecommunications System (UMTS) is one of the third-generation (3G) mobile telecommunications technologies, which is also being developed into a 4G technology.
-Unlike EDGE (IMT Single-Carrier, based on GSM) and CDMA2000 (IMT Multi-Carrier), UMTS requires new base stations and new frequency allocations. However, it is closely related to GSM/EDGE as it borrows and builds upon concepts from GSM. Further, most UMTS handsets also support GSM, allowing seamless dual-mode operation
Jan 08, 2011 | Nokia E63 Cell Phone
I havin nokia e71 and its not showing my network lines ... i cant call n incoming is not also coming...
Only thing I can think of.. is that maybe the phone is set to use UMTS only and not GSM?
Try looking under:
Menu / Tools / Settings / Phone / Network
And see if the option for Network Mode is set to GSM or UMTS or Dual Mode.
If it is set on UMTS try changing it to GSM and see if it will then connect to the network. The Dual Mode option should allow it to switch between the two automatically. I prefer setting my phone to GSM as it will help save on battery power.
Jul 05, 2010 | Nokia E71 Smartphone
I am having N73 but the network is not comming what should i do
Try looking under:
Jul 05, 2010 | Nokia N73 Cellular Phone
Nokia n 73 signal disappear
Sounds like you're getting 3G interference. It happens because you're just on the edge of a 3G area. The same happens to me on both my N95-8GB and N73. The phone is detecting a weak 3G but it's not enough to make a call.
You need to go to "Tools" -> "Settings" -> "Network" and switch from "Dual mode" to "GSM" The phone will say it needs to restart, select "Yes"
The phone will then restart and you shouldn't suffer any more 3G blackouts.
Hope that helps.
May 22, 2009 | Nokia N73 Cellular Phone
I have Nokia N95-2 8GB H3G UK Its Firmware Version is V 30.0.018 23-07-08 RM-320 © Nokia N95 (93.02) when i go to "Settings" then open "Phone" then "Network" then "Network Mode" its just showing me...
May 12, 2009 | Nokia Cell Phones
I have N95 8GB
To be abble use GSM mode you need to change your product code and get rid of 3firmware,which void your warranty and you wont be abble acces certain services (Planet 3) . You'll need programm called NSS to change your Product code.
May 12, 2009 | Cell Phones
Umts with nokia 6630
My Phone Have Some Problam.
Phone Used 2 Antennas For GSM & UMTS
I am detach Gsm Antenna (It Has 2 Terminals )
I Remove That Terminal and Now Phone Reciving UMTS Only
SRI LANKEN IDEA
Jan 08, 2009 | Nokia 6630 Handheld
Nokia N73 Cellular Phone Logo
124 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
