Question about LG Televison & Video
When I hook up my computer via HDMI to my LG 32LD450, screen doesn't seems to be showing right, what I mean fonts are blur and everything is not look as computer monitor. I know there is RGB VGA connection which I am using it now, however, I like to make digital processing connection and want to have DVI(HDMI) benefit. Do you have any best solution for this either answer this LCD TV cannot be perfect 32inch DVI connection computer monitor?
    Sergeant:
  • 122 Answers
When plugged into the TV via HDMI make sure that the resolution in the "Display settings" match the specification of the TV.
Posted on Jun 28, 2017
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
SOURCE: LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
Posted on Nov 09, 2008
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 458 Answers
SOURCE: RGB port
A VGA & RGB port is the same thing. RGB is Red/ Green/ Blue for seperate input & VGA the video graphics array which does the same thing.
A DVi is an entirely different type of input port for digital input where your VGA port is more for analogue type inputs
Posted on Jul 13, 2009
  • 4234 Answers
SOURCE: my sharp tv is pc ready. I hook everything up and
There are a number of things to check here:
1) Verify that the resolution on the PC is set to a supported level for the TV. Usually the TV will show "no signal" if the resolution is out of range or the message "out of range" will appear.
2) You don't indicate whether you are connecting to a desktop or laptop. If a laptop, you may need to turn on the external monitor. This is done by using the function key and either F5 or F6 (the key should have a picture of a screen on it). Hitting this combination will toggle between the main screen with.without the external monitor.
3) Verify that the TV port is selected correctly (AV1,AV2 etc)
4) You will need a separate cable or the audio regardless of the system type. Also verify that the audio cable is in the corresponding audio input jacks for the video option selected.
If you have completed the above and it still doesn't work, please post the details about the computer being used and the exact cable setup that you have and I'll check into this further.
Thanks,
Dan
Posted on Mar 13, 2010
Tip
Lost password for LG's 32LD450 flat screen television
Password access for LG flat screen televisions 32ld450, go to http://www.lge.com .If you have lost your password, try 0325. You can find lots of information to do with other problems and models.
on May 08, 2011 | LG 32LD450 32 In. LCD HDTV
I have a 32LD450 LG TV it will only show picture or music options from usb no movies??
LG 32D450 LCD TV doesn't support video playback from usb. The USB 2.0 input of this particular model can only read jpeg format (photo/snaps) and MP3 format for music playback. please click the link below and see the technical specification and USB input.. http://www.lg.com/us/tvs/lg-32LD450-lcd-tv
Apr 17, 2012 | LG 42LC2D 42 in. LCD HDTV
Every time i try to hook my lg 290c up to my computer it makes the "failure to connect" sound. it dosent even show up in my computer. what do i do to access it?
I am glad to HELP YOU!
You're right, some of the LG 290 users reported that even using the right USB data transfer cable the computer ALWAYS searched for the right driver to establish the connection but never succeeded.
As in your case - it was about a missing driver.
But now I will show you a LITTLE-BIG SECRET about the data transfer via Bluetooth. Sure, I know - the LG 290 doesn't allow such operation via Bluetooth.
But this is how I mad it possible:
# go to MENU > SETTINGS > BLUETOOTH > POWER > OFF > OK
# press END now
# you're on the MAIN SCREEN; dial ##7764726290 and SEND
# enter 000000 > OK
# go on BLUETOOTH SETTINGS > OK
# if the server [FTP] is underlined/highlighted > OK
# YES > OK
# ON > OK
So from now on you will be able to transfer data to/from PC via Bluetooth by using Bluesoleil application.
I've found this trick quite a while ago on howardforums.com [... if I'm not wrong].
GOOD LUCK!
... and don't forget to RATE, please...
Apr 21, 2011 | Computers & Internet
HELLO, I've just bought LG 32LD450 tv and have no idea how to switch freeview. This tv supposed to be with freeview already, but I've checked my manual and can not find it. Could you please help me.
Do you mean free over the air HD?? If so hook up a UHF antenna to the ATSC connection on your tv and you will be able to receive all over the air broadcast HD tv signals in your area for free.
Hope that was answer you were looking for - if not please be more specific in your description
Mar 04, 2011 | LG 32LD450 32 In. LCD HDTV
Screen stays in analog mode
analog usually means its hooked up via VGA cable
digital means its hooked up via DVI cable
Sep 04, 2009 | LG Flatron L1750S 17" LCD Monitor
No signal from ps3 to lg tv via hdmi
if this is the first time you've hooked it up via HDMI then you have to go back to the old cables first. Hook those up to the old TV or the new one, then go to settings and switch to HDMI. It will give you 30 seconds to change the plugs again so you can view the HDMI. Then select ok. Hope this helps
Aug 20, 2009 | LG 42LC2D 42 in. LCD HDTV
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
Turns on but no picture or sound and the machine sounds quiet?
I was having the same problem, and what seemed to fix mine was my hard drive. I keep my 360 on it's side and it [hard drive] was falling out a little. I pushed it back in and that seemed to do the trick. Also, when I fix my red rings, I just turn the console off, unhook EVERYTHING and leave it out for a minute. Then I hook everything back in (power cord, hdmi cable, ethernet cable, and hard drive) and it usually works out ok. I'm not saying that fixes everything, but, it has for me in the past.
Dec 31, 2008 | Microsoft Xbox 360 Console
I've hooked up my LG 47" 1080p widescreen to a LG HE903PAW audio receiver / 5 disc dvd player with upscaling capabilities. I have tested the speaker system and everything's connected properly....
I was talking with LG on virtually the same problem. I have a samsung blu-ray player hooked up via HDMI. Even though the blu-ray is outputting 5.1, 6.1 or 7.1, the LG is only outputting 2 channel unless you switch to pro logic. LG states that this is a known problem and that you are to return the system to where you bought it for a replacement. Call the 1-800 number and they should give you the same answer.
Nov 23, 2008 | Audio Players & Recorders
Televison & Video Logo
75 people viewed this question
Computer Repairing
Computer Repairing
