Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
I have landline home i have dsl 1mb i want if i connect telephone dialtone with linksys device then i can operate pc or iphone any where in the world
  • Linksys Master
  • 7,733 Answers
It is not possible because you need an ISP provider like a DSL or other type.The telephone line is only for voice not data.
Posted on Mar 20, 2011
Cannot connect through verizon dsl westell 6100g modem
Call verizon dsl and make sure you have your account username and password (given to you by verizon when the connection was put in your home) when you get them on the phone. also make sure you have the username and password for your Linksys device.
Aug 14, 2012 | Linksys Wireless-G Broadband Router
How is a wireless system different from a hardwire security system?
Wireless systems are much easier to install. It really depends on the place you want to secure. Two-story homes are ideal for wireless due to installation ease. On the other hand, one-story homes and business may be more suitable to hardwire systems. There is no difference in the operation.
Jul 18, 2012 | Safety Technology Wireless Home Security...
Internet drops in and out. seems to connect again once the landline phone is used. new filters have been brought - no difference. phone line is clear. ISP have no known problem. speed test is very low. is...
If it is connected to a DSL modem then chances are that it is the modem dropping the connection every time a spike in line voltage occurs. Might want to try directly connecting to the modem and seeing if it still happens, if so then it is the ISP that you need to contact. If not then your router may be on the fritz.
Best of luck
May 24, 2011 | Linksys WAG200G Router
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
When i use my landline i am being disconnected from the internet. can i change the linksy freq on the router
Do you have a filter on each telephone device attached to this telephone line?
One is required at each device or telephone when using a dsl router.
Jul 21, 2009 | Linksys Wireless-G WRT54G Router
Model 21518 GE Bluetooth Telephone Adaptor
I see the same thing and it appears that this is the way it works. Without the landline you will get the beeps but can still make and recv calls. After the beeps, dial #1#phone-number#, and it will call that number. Guess that is what they mean when say works without landline.
Apr 12, 2009 | GE Lands Phones
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
My landline phone dialtone I get a beep,beep,beep before dialtone
I had the same problem. To fix it, I unplugged the base from the wall, and the battery from the handset, left it all unplugged for 30 seconds, and then replugged everything back in. It works fine now.
Jan 06, 2009 | AT&T 650530003417 Cordless Phone
Linksys Phone Adapter with Router Model SPA2102-R Connecting to Internet
from the cable modem or dsl connection, connect to WAN on the linksys device From PC port to the computer. you will have to make sure if all the port or opened. Normally DATAONE will not block any ports but its always adviceable to check if all the potrs are opened. you will have to put your mac code on the modem. If that does not work you might have to clone your device (information transfer from modem to your device) and you should be good to go...............
Nov 19, 2007 | Computers & Internet
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
121 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
