Question about Hoover Washing Machines
Hi,\r\n I have a Hoover Performa Eco 1200, WB120 model washmachine. It flooded the room one wash, so I removed the top to look around and saw the hose going from the innermost water intake solenoid to the top of what appears to be an off-white plastic manifold on the back of the spin drum with a pump on its upper left had come off. I reconnected and left the top off for the next load of laundry. When the dial on front of machine hit's the electric wall outlet symbol between 7 and 8, that hose explodes off (had the fastener on it too) and spews water everywhere. Looking into the opening to the manifold, there is no opening after all. It seems it is manufactured to be blocked off. There is not a blockage caused by lint or dirt, but it's just plastic, as if there never was an opening, but this machine has worked for almost 10 years until now. What am I missing here? I am going to disconnect the inner solenoid for now as I don't need what I think is the dryer function. Thanks for your help.
2 Suggested Answers
SOURCE: i am looking for the instruction manual for the hoover performa e
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Posted on Mar 23, 2009
Hoover performa 900 model number washing machine user guide
Check out this site and see if you can find your model number of your machine.....
Aug 25, 2014 | Washing Machines
Hoover 1200 performa dosnt seem to be getting hot? the drum feels cold when washing, any ideas?
Morethqan likely a faulty heater element, this is located a t the bottom rear of drum, remove rearr panel of washer to access, you will need a meter to test it.
Feb 07, 2010 | Washing Machines
Hoover performa 1100 ac110 not emptying
After syphoning water out of drum, remove and clean filter located at bottom front left of washer, if there is a screw in the filter cover, unscrew this first.
Remove filter by unscrewing anti-clockwise.
Feb 06, 2010 | Hoover Washing Machines
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Nov 01, 2009 | Washing Machines
Hoover performa 1200 bangs when spinning.
it sounds like you spider as broke you will need a new drum as they are not bolted on
Jun 21, 2009 | Kenmore 24872 Top Load Washer
Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Apr 21, 2009 | Washing Machines
User guide for hoover performa eco 1200
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
Mar 22, 2009 | Hoover Washing Machines
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
Washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Dec 11, 2007 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
