Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
My Logitech MX 1000 mouse has become erratic after I purchased a 2TB Iomega external Hard Drive. Is there a problem with this combination of hardware I have tested for any malwar etc with Norton 360 and Microsoft Essentials and PC Tools registry mechanic and these find no problems. I have checked with update mouse drivers and have the latest for this mouse. When I turn the Iomega drive off the problem still exists
SOURCE: logitech lx7 mouse
Go to logitech.com, then download and install Setpoint.
Click Start, then Logitech, then Connect Utility.
Follow the instructions as they appear onscreen.
Posted on Sep 09, 2008
frcs68
  • 1605 Answers
SOURCE: Logitech MX420 mouse w/XP SP2 MCE
could you send me ink for fire fox forum??
also, can you make a copy of the config.sys from your computer??
I don't use fire fox, so, I need to see what is configured.
Thanks
Posted on Nov 09, 2008
  • 31 Answers
SOURCE: Erratic Logitech cordless optical mouse
ive had the mx700 for two years and im very comfortable with it.
I think you problem lies not with the mouse or the driver, but rather the mousepad.
Since the mx700 is not a lasermouse, but "only" optical, it still needs a decent pad to work flawlessly.
Ive had problems with these kind of mice using blank paper, magazines or tablesurfaces.
Try to get a real mousepad from somewhere (should be really cheap), that should do the trick =)
I upgradet to a razer diamondback later which is a laser mouse (1600dpi, while optical mice (with the red light) have 800dpi). Some ppl say that this is too much, and not needed (you can get even higher specs =) but i felt a world of difference, it just works everywhere! (except for mirrors and glas =)
Posted on Jan 23, 2009
SOURCE: erratic mouse movements
dust on the optics of the mouse. cleaned it with a Q-tip.
Posted on May 15, 2009
  • 38 Answers
SOURCE: logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Posted on Jun 01, 2009
How to take apart a gdhdu hard drive
Not a good idea. With the correct screw drivers it can be done. WHY? there is nothing to fix, and most likely it will be useless when you finish.
Apr 18, 2013 | Iomega GDHDU2 2tb Select Desktop Hard...
Logitech Cordless Desktop 5500 Revolution Keyboard Mouse Software won't load.
Toby Christensen,
You may need to choose if your OS is 32 bit or 64 bit when installing the software for the mouse and keyboard. Click the links below for resolutions.
Logitech 5500 Keyboad and Mouse
Logitech 5500 Keyboard and Mouse FAQ's
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell XPS 8500 Desktop Computer; Intel Core...
Iomega 2TB Prestige External Hard Drive NOT COPYING FILES
A shot in the dark but partition it as two 1tb drives.
Sep 02, 2017 | Iomega 2TB Prestige Desktop HDD USB
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
Am I able to password protect the 34974 Iomega external hard drive? I am not interested in encrypting, just having a password so it cannot be seen by others
Plug your Iomega hard drive into the USB port on your computer. Click the "Start" button and choose the "My Computer" icon. Double-click on your Iomega hard drive's icon. Right-click in a blank space on the window and choose the "New Folder" option from the menu that appears. Highlight and drag all of your data into the new folder that you created. Right-click the new folder and select the "Properties" tab. Navigate to the "Sharing" tab and check the small box next to "Make This Folder Private." Click the "Apply" button and then choose "OK." Use your Windows login password to access the folder and the contents. Hope this helps
May 20, 2011 | Iomega Select 2TB USB 20 Black External...
Just brought 2Tb iomega hard drive, got home, pluged in, status light stays flashing and windows doesn't pick it up... Roy
> just brought ...
Just take it back to where you bought it, and get them to show you that it works.
If it does not work, they will replace it.
Dec 14, 2010 | Iomega 2TB Prestige External Hard Drive
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
91 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
