Question about Vacuums
I have a Brother Nouvelle 1500S and it keeps looping the bottom stitch. I have re-threaded, re-inserted the bobbin, am using the recommended thread and changed the needle? It is still looping the bobbin side stitch?
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
SOURCE: i have the brother Ls-2000
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Posted on Feb 07, 2011
  • 2976 Answers
SOURCE: I have an expression 2038
If the bobbin thread is too loose, remove the bobbin spool AND carrier.Thread the thread through the tension clip on the holder in the normal way. Hold the thread and lift it. If the bobbin slides down, tighten the small screw 1/8 turn clockwise, until you can lift it with little or no sliding.
Posted on May 07, 2011
Testimonial: "fantastic to have someone to talk to who understands thank you "
  • 1833 Answers
SOURCE: Just got white E-Z sew
The thread should be going counter clockwise. You probably have to pullabout 3 inches of thread out of the bobbin to be safe, and pull that up overthe plate and drape to the left. Then pull about 5or 6 inches of thread outfrom the needle. Try holding that thread somewhat taught and lower your needleup and down with your side dial and see if it finally loops the bobbin thread. Hope this works.
Posted on Jun 25, 2011
richroth
  • 9472 Answers
SOURCE: After I threaded the needle
Make sure the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. Also, make sure that the needle is not bent at all. Just the slightest bend will hamper the machine from working correctly.
Posted on Sep 12, 2011
Excessive thread under fabric...jams up the machine. Have rethreaded, replaced needle, rewound bobbin...no difference. Sews a few stitches then under thread just gets jammed in machine. Viking 1100.
So the underside looks more like a **** rug? 2 things to try. The problem is the bobbin. try flipping the bobbin over (take it out, turn it over and put it back in). The writing on the bobbin printed in the plastic should be on the top and no writing on the underside. 2nd,make sure it's threaded front to back and not looped around the needle. I have the same machine~it did that too!
Sep 05, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
My Singer portable (#6202/62120) keeps stitching nicely on top, but the bottom stitching is all knotted up! It's driving me crazy! I have tried everything. Any help would be greatly appreciated....
The bottom side is effected by the TOP tension. First make sure the top is threaded correctly. Best thing to do is completely unthread it and then thread it again. Then check the tension and make sure it is not too loose. Check the needle to make sure it is inserted correctly and not bent.
Once you've done that then you can take a look at the bobbin tension and make sure it isn't too loose too. Make sure the bobbin is in the case correctly, wound correctly and that the bobbin case is completely inserted right. You will hear and or feel a slight "click" when it goes in correctly,
May 24, 2011 | Singer Vacuums
I amhaving trouble with the thread brahing and I don;t know if it is the tension. Which way should the pobbing turn right or left and how do you set the tension For my Singer sewing machine
Check the upper threading and make sure it is threaded correctly. When you pull on the thread before it goes through the needle does it give a bit or does it break? If it is breaking when you pull then the tension is way too tight or it is threaded incorrectly. Make sure it isn't looped around some guide along the line too.
For the bobbin thread... when it is in the bobbin case outside of the machine dangle it by the thread. It should hang there until you flick your wrist a bit, which should cause some thread to release and drop the bobbin down towards the floor a bit. (If it just pulls out right to the floor it is too loose). Most bobbin tension is tightened by a small screw on the bobbin case near where the thread comes though. Breaking thread would not be from the bobbin thread being too loose. Too loose would cause looping on top side of the stitch not breakage.
Make sure the bobbin is in correctly. You should feel and hear a slight "click" when the bobbin goes in correctly.
Apr 26, 2011 | Singer Vacuums
Jc penny model 1710 sewing machine, the stitching isnt tight
You do not say if it is the top stitches or the bottom stitches for the bottom tension, check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
For the top stitch, tighten up on the tension adjustment on the front of the machine which looks something like this:-
images?q=tbn:and9gctmqnuzdetdofn3rmptgx4d6h3wsbbewgyursvcfmpbxpewspjy
Apr 11, 2011 | Vacuums
I have a Janome 8048. Here's my problem: As I sew I notice that the stitches on the top of the fabric look the way they should on the bottom side and when I take the material off the machine and flip it...
I haven't sewn in years. A sewing machine has a tension control on top and on the bobbin. If the intersection of the top and bottom threads is not in the middle of the sewn material, you have to adjust your tension.
In your case, what I think you are saying is that the stitch on top is just a straight line and on the back it disappears into the fabric.
To correct this, lower the top tension by loosening the tension adjuster on the thread where the thread loops around the small pulley.
Also, you could tighten the tension on the bobbin by slightly tightening the small screw on the side of the bobbin.
Gary
Feb 21, 2011 | Vacuums
My sewing machine is otherwise perfect..but the stitches hv a tiny dot from the thread in the bobbin case...wat to do??
Tighten the bottom thread or loosen the top thread a little. There should be a little screw on the bobbin holder where you can adjust bottom thread tension.
lp
Dec 29, 2010 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
