Question about Garmin nuvi 265 Car GPS Receiver
Can I charge it with a connection to my computer will that be enough of a current to re charge the battery? Or do we have to buy a special wall charger. I am not sure if you are syaing we need to leave our car on all night to fully charge this device?
  • 1,514 Answers
You can charge it through your computer. If you connect your satnav to your computer with the mini USB lead it will charge. A full charge takes about 8 hours.
You can charge through your car cigarette lighter socket either. This takes around 4 hours. The first charge should be continuous until it's charged so you might be better using your computer. After that if you plug it into the car it might be enough to keep it topped up depending on how much you use it.
NOTE: Don't start the car with the satnav plugged in. Unplug it first and when you've started the car plug it in then as there may be a surge of power when the car starts which has destroyed many satnavs.
Posted on Mar 21, 2011
My panasonic Hc-v100 camcorder is not charging when plugged in to USB cable - cursor light is not flashing and battery is running down
you DON'T charge the camcorder with the usb cord,you only move files between cam and computer,you need a power cord that plugs into the wall,see pic, LETO 2A AC Power Charger Adapter USB Cord For Panasonic HC V100 HC V500 HC...
ihave the same camcorder,
Mar 24, 2015 | Video Cameras
Sylvania mp3 player charge
Not all computer USB ports put out enough current to charge batteries. If you're going through a hub, try connecting it directly. Try a different USB port if you have one. Try plugging it into a wall outlet if if you have an AC-USB adapter.
Jan 04, 2014 | Audio Players & Recorders
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
I Have Misplaced My Charger And I Am Wondering If There Is Any Other Way To Charge It Like Maybe In The Computer?
Yes, you can charge the battery by connecting the camera to a powered USB port. Be aware that not all computer USB ports put out enough current to charge batteries, and you want to connect it directly, not through a hub. Alternatively you can use a USB charger that plugs into a wall outlet; such devices are available for cell phones.
Jul 30, 2011 | Vivitar ViviCam 8025 Digital Camera
Will a usb cable fitting the Vivi Cam 8025 charge the lith battery; I can't locate a port on the camera to plug in a wall charger?
Yes, you can charge the 8025 through the USB port, assuming the computer puts out enough current to do so (not all USB ports do). Or you can take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet.
Dec 04, 2010 | Vivitar ViviCam 8025 Digital Camera
Can i plug my vivitar 8025 in the cumputer and will it charge
Assuming the USB port on the computer puts out enough current, then yes. Not all USB ports put out enough current, so make sure the red LED lights up while charging. If the computer doesn't put out enough current, then use the supplied charger and plug it into a wall outlet.
Jul 02, 2010 | Cameras
How do I charge the battery
From page 7 of the manual, you have two choices.
You can charge the battery with the USB cable, connecting the camera to a computer. Bear in mind that not all USB ports put out enough current to charge a battery.
You can use the supplied battery charger. Put the battery in the charger and plug the charger into a wall outlet.
Jun 22, 2010 | Vivitar ViviCam 8025 Digital Camera
Iphone not charging
To charge any battery (also on iPhone) both negative and positive poles of the cable and battery need to connect. Check the inside hole of the lightning plug on your iPhone while the device is turned off. Most of the time dust and dirt gets clogged in the small connector. While your phone is in your pocket, purse or hands 24/7 this intrusion is inevitable filled with dirt. Soo much that cable and battery don't connect to exchange current. Take a toothpick and gently check if any dust/garbage/paper/stuff is in there? The inside of most clothing pockets, were we all keep our smartphone are filled with dust and small dirty particles. Unclog the connector and try to charge it.
Aug 07, 2009 | Apple iPhone Smartphone
PSP chager
Try a different outlet in the wall, it might be the outlet, if it isn't the outlet, maybe it's the power cord or the battery. If it's not that, then it's your PSP. You'll have to send it to sony for a new one if you want it replaced and if youve had it for over year you're going to have to pay $90. ------The fact that it turns off when the USB DC-in is connected and that it will not power up without the battery lead me to think that either the USB charging cable is just not supplying enough amps to run the psp standalone nor charge the battery very quickly, or something is odd in the PSP itself. I'm guessing when you plug something into the DC-in socket and it detects 5V then it switches to that as a source, if the USB cant supply the current it wants then it shuts down (just a guess).
May 06, 2009 | Sony Battery Charger for PSP
Garmin nuvi 265 Car GPS Receiver Logo
130 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
