We have a simpson 806 encore washing machine aprox 8-10 yrs old. recently it has started leaking from underneath some where.also the display has PC on it . we have lost our user manual. does this flashing PC on display have any relavence on where water is leaking from. (eg pump control, presure control) hope you can give us an idea what it could be, so i have some idea what to tell repairer. thanks Paul Smith
    Brigadier General:
  • 6,277 Answers
Everybody but everybody, including me, looses the manual!
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
I doubt the manual will tell you where the leak is and I suspect you will have to rely on the Mr Fixit to find and cure, sorry.
Good luck,
John C.
PS I do not have any fault codes for Simpson machines but could it be that the drain pump filter requires cleaning- 'P' for pump?
Posted on Mar 20, 2011
Why does my Simpson encore 556 display SF on the Display panel. What's it mean?
If the control panel detects that the motor is not rotating then it will beep & show that fault.
Feb 26, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Says sf on screen Simpson encore 807
i have a Simpson encore 807 & its displays DF what does that mean... as it keeps beeping...
Jun 30, 2009 | Washing Machines
Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Jan 11, 2009 | Washing Machines
Simpson washing machine encore 756 displays error df and will not complete cycle
our simpson encore 756 flashes SP can anyone tell us what it means and how do we fix it thanks mark
Aug 03, 2008 | Washing Machines
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
