Question about Belkin F5D7234-4 Router
Suddently the wireless connection is missing from my router, aftern i shut down and i reset, the wireless light is still not ON, the only light on inly for internet, router, and power. 2 days ago the wireless is fine, how to troubleshoot this?
  • Belkin Master
  • 7,733 Answers
What is the problem? Can not connect your PC to the router?
Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Mar 20, 2011
Im having problems connecting to the internet after i got a netgear wireless dual band router to my pannaway modem
First check that router light is blinking. If not, need to repair or replace.
If light is blinking, you need to reset it. There will be a reset button back side of your router, press and hold it for 30 seconds. Restart your router and reconfigure.
Also check that you had enabled wireless setting. Ask here if problem still occurring http://www.vtechsquad.com/wireless-router-support/
Feb 24, 2013 | Computers & Internet
My D-link router (dir 615) saying is connected but have no internet access
Wired or wireless? Check all cables, have you tried to connect with a Ethernet cable to the ISP modem, if it connects, try connecting via the cable to the D-link. Work you way through the devices one by one.If it connects via the cable, it's the computer's wireless adapter. Will other computers connect? Or contact your ISP to verify the signal, have a tech come out to analyze the signal. It may be outside. It's happened before, to me.
Dec 26, 2012 | D-Link DIR-615 Wireless Router
Just bought a new Belkin 300N wireless router. My pc does not link to it all i get is a limited or no connectivity via Ethernet cable. Ive updated the driver checked all the standard settings all is...
GENERAL ROUTERS RESETING 1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Jul 30, 2011 | Belkin Powerline F5D4050 Network Adapter
Loses internet connection I unplug or turn off the router then I will get the internet service for a little while it then shuts down. I contacted the cable service they sent a signal to the router box...
There could be a problem with this router's firmware that is why you are experiencing intermittent connection with it... Try hard resetting it and try reconfiguring it back again
Mar 15, 2010 | Linksys WCG200 Wireless Router
Dlink wireless wbr1310 connection problem
Try this,
Shut down everything starting with your computer, then the router, then the modem.
Wait 30 seconds. Restart everything in this order:
Modem first (wait for all the lights to come on) then start your router (again wait till everything lights up and settles down) finally start up you computer.
Check to see if you can connect to the routers control panel which is usually 192.168.2.1.
In the control panel there should be a place to enter your computers MAC address, usually under MAC Address Filtering. To find the Mac Address of your computer, go to Start/Run/ when the window opens type CMD and hit enter.
A Dos window should open, type in the following. ipconfig -all
It should then display your Mac Address which you will want to write down so that you have it ready to type into the Mac Address filter .
After entering all the info. Restart everything just as I instructed in the beginning and you should be good to go.
Sep 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My computer connects with my wireless router but no internet info passes through. the internet works when i plug directly from the cable modem.
power cycle your modem and your router and shut down the pc. before plugging router back in, hold reset button down for 1 min. plug all back in and start pc up. should have connection.
Jul 22, 2009 | D-Link AirPlus DI-524 Wireless Router
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Bad connection. dropped internet when connected with mac wired or wireless
I'm not sure but it could be that the particular router has some hardware issues. I bought a Belkin wireless N router a few months back and i had the same problem. It only had a short range and kept cutting off in between. I exchanged it with a new router and voila!. it works fine.
And the other thing i've come to notice. At times having the router under the desk or at a corner might not give off enough to provide a connection within the adjacent room so I've had to place the router in a open and unobstructed place. So much for belkins super signalling.
Aug 05, 2008 | Belkin F5D8631-4 Router (F5D8631au4A)
Belkin F5D7234-4 Router Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
