Question about Intel D945GCCR Motherboard
My pc auto shutdown - Intel D945GCCR Motherboard
  • Intel Master
  • 7,733 Answers
Shutdown without a user command relates to any hardware or software issues.It can be a HD issue or Video card.
If you can please post more info. about your PC brand,OS,etc...
Posted on Mar 20, 2011
Whats the codes p0685 an p0688 on a 2004 chrysler pacifica mean
P0685 CHRYSLER - Auto Shutdown Relay Control Circuit Failure
Short or open in Auto Shutdown (ASD) relay circuit
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Possible Causes
- ASD relay circuit is open or shorted
- Failed Auto Shutdown relay
- Failed ECM
Tech Notes
Check all the ECM fuses, if the fuses are OK try replacing the ASD relay.
P0688 CHRYSLER - Auto Shutdown Relay Control Circuit Low
The Front Control Module (FCM) has detected the supply voltage below an acceptable value
Symptoms
Possible Causes
- Failed ECM
Tech Notes
Dec 29, 2014 | 2004 Chrysler Pacifica
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
My acer aspire 4736z auto shutdown within a few seconds after on. Is there anyway to fix it?
yes there's a fix a simple one
1.it may be due to a loose ram..
2.your laptop may be over heating with leads to auto shutdown
solution : a service will solve all your problems !!
Jun 14, 2011 | Acer Computers & Internet
Why do my laptop cannot be turn on. It automatically shutdown by itself even if in full battery?
Reasons might be:
First, there is a problem on your Operating System/
Situation: If its auto shutdown upon booting or upon loading windows/
**solution:Repair/Reformat the OS used/
Second, there might be a problem in you Memory Card/
**solution: Try to clean your Memory Card using an Eraser/
Third, make sure that you placed your laptop on a clean and cool area/let the air on the fan flow/most probably your CPU fan might be affected for that and leads you to auto shutdown/
**solution: clean the cooling fan,
Nov 25, 2010 | Computers & Internet
PC Getting auto shutdown
The most common reason of a PC getting auto shutdown is that the processor may be getting over heated.
Every processor has a TjMax temperature. when the processor reaches that temperature, it starts throttling(slow down) and if it continues to become more hotter then it automatically sends a shutdown signal to the Computer
Solution:-
  • Clean the Heat-sink.
  • Check the fan speed.
  • clean the cabinet.
  • use thermal paste over thee processor.
  • Make sure there is proper ventilation in your cabinet.
Hope this may help you......cheers:)..plz vote
Sep 24, 2010 | ASUS P5PE-VM Motherboard
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
Aug 25, 2009 | Acer Extensa 5620-4020 Notebook PC
How to make easy shutdown a pc
In windows xp or vista you make it easy, using press the power button in the windows environment, it will auto matically shutting down the pc.
regards
Krishan
May 11, 2009 | Computers & Internet
Location of Auto ShutDown Relay for 1989 Jeep Cherokee
Auto shutdown relay and fuel pump relay are by the battery under a cover.
Jun 23, 2008 | 1989 Jeep Cherokee
Intel D945GCCR Motherboard Logo
65 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
