Question about Garmin nuvi 265 Car GPS Receiver
We were traveling with our garmin and the rental car was not charging the garmin as we thought it was. We think the battery might have run down. We have tried to charge it with our phone charger which has not worked and we also tried to charge it in our car but all it does is blink and go off. When we click it on it ony keeps blinking.
  • kdamato Mar 20, 2011
    We have a charger on our computer will that be sufficient to leave it on overnight? Or do we have to buy a particular garmin charger? Please advise
  • 927 Answers
First, let me say that letting the battery run down completely does no harm in a rechargeable device. As a matter of fact, these types of batteries perform best in the long run if they are run fully down and charged fully up.
Try leaving the unit turned off and recharging for at least 1 hour, then power it up and see the result.
Gary
Posted on Mar 20, 2011
  • 12,061 Answers
If what you say is right it would need at least 10 hours charge with at least 6 hours before you would even be able to see & do anything with it.
Charging with the phone charger will not really work, as the current supplied to a phone is way lower than a GPS. Even if it did charge it would take like 24 hours...
You will have to either get a wall charger or a car charger that you are sure is working and charging and leave the GPS on charge at least for overnite.. It should be Ok next day. If not, then you have a fault with the unit, for whatever reasons.
Garmin nuvi 2455 won't charge on dc but charges on ac
ya no quiero tener la suscripcion a http://wingo.mx x favor yo no la utilizo y me kita mi saldo
Dec 31, 2013 | GPS
Can not get StreetPilot C340 to turn on
Yes its most likely the battery, if you plug it into the charger, I assume it powers up normally? Il see if I can get you instructions on battery replacement. I remember there was one for your model or a similiar one. Hold on.
Oct 03, 2008 | Garmin StreetPilot c340 GPS Receiver
My gps battery says low battery and shuts off when I set it down after putting in travel info. What to do ?
Check the power on your 12v car cord. The internal batteries are low and are not being charged by your vehicle system. The fuse may be burned out in the 12v car plug.
Dec 19, 2009 | Garmin StreetPilot c340 GPS Receiver
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
My rental Garmin c330 went mute after 10 minutes.
well if its rental at least you might not have to pay for repairs. it could be the audio chip. But just to ensure that you didnt accidently mute the unit see if the speaker icon has a red X over it and then take it off.
Low battery can also interfere with voice so ensure its fully charged
leaving it in a hot car can also damage chips (we uasually ask if they had fish with it (chips) as heat in cars melts many items incliuding silicon chips.
Jun 23, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin died and will not turn on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 350
easy solution...you need to keep this plug above attach to the the Garmin 350...when charging in the car or at home ...plug the power source to the back8dac8e5.jpg. Hope this will help...i had the same problem.
Feb 21, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 330 battery
"my garmin c330 will not charge in the car while traveling?it has a full charge when i head out but after 4 hours it shows low battery,i was thinking the gps was supose to charge with the car adapter plug in.my will not charge."
There is a problem with the cable or the cigarette lighter power supply. If the cigarette is working then when you start the car the Garmin should turn on and when you turn off the engine the Garmin should shut down. If you are manually turn the unit on/off then it is not running off the cigarette lighter power supply. Check to make sure there is power coming from the cigarette lighter.
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 265 Car GPS Receiver Logo
21 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
