Question about VAX Appliances 2000 Canister Vacuum
My husband uses talcum powder liberally and we have a long haired white dog. I barely get 12 months out of vacuums. Have had (2) Miele Dog & Cat vacuums with additional filters attached - can you recommend something that will cope with the above conditions and last?
    Master:
  • 324 Answers
You can build a homemade soot trap like what oil burner service reps use. Please refer to the drawing. You start with a widely availabe bucket with an airtight lid (Home Depot sells one in their trademark orange color for example). Along with the bucket, you will need about 30 inches of PVC pipe - ideally you will get the diameter that matches your vacuum cleaner hose attachment. "Schedule 40" PVC pipe will work fine. This refers to the less expensive thickness of pipe- any home improvement store rep can help you with this, and if you bring in your hose and explain what you need to do they will gladly help you out! Finally, you will need a tube of silicone RTV sealant. Cut two holes matching the size of your PVC pipe into the lid of your bucket, and cut the pipe into two sections- one that will sit three to four inches from the bottom of the bucket, and one that will sit one or two inches below the lid. Put them into position and use the RTV sealant to hold them in place and also provide an air-tight seal. On the lid, label the side that has the long pipe INLET and the side with the short pipe TO VACUUM. This is CRITICAL so make sure you do it! Labels, paint, marker, crayon- whatever. Label them NOW!
Finally, you need a section of flexible plastic hose to connect your trap to your vacuum. Six to eight feet should work fine. You will have to be creative to make sure the connection between your new trap and vacuum are air-tight, but IMHO this adds a little adventure to the project... you want something easy to attach and remove, and by no means do you want to do anything that prevents you from taking your new trap off and using your vacuum normally. Hardware stores are bursting with all sorts of adapters and stuff! The same goes for the inlet side of your trap, but hopefully you matched the pipe up to your pickup hose to where it makes a nice tight fit and works without adapters.
After the RTV cures (about 24 hours) and you are satisfied that everything is in order, you are ready to use your soot/dust/fur trap! Fill the bucket about 1/3rd of the way up with water. Make sure that the long end of pipe is under water by about 2 inches. It is VERY IMPORTANT that the end that goes underwater (The INLET) is hooked to your pick-up attachment.... You should have labeled it INLET already.
The whole idea is that whatever your vacuum sucks up gets pulled underwater first, trapping it before it gets near the vacuum cleaner. It has worked for decades for oil burner service techs to keep furnace soot out of their vacuums, which would be destroyed after one or two uses otherwise.This will easily trap dog hair and talcum powder. Be forewarned that inside the bucket it will get very messy and it is vital that you clean it after every use.
Good Luck!
Posted on Mar 20, 2011
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
We have a dyson dc27 total clean, this is the worst vacuum we have ever owned we have dogs so we vacuum about every other day our dogs have fin short hair and its hard to pic it up we have to go over the...
My vacuum engineer friend loves Dysons ~ he says that they keep him in business!!
The only machine that I have found any use on animal hairs is the Miele Cat'n'Dog model.
The turbo brush is excellent.
Dogs shed most of the time so that means to keep onto of the hairs you need to vacuum most of the time (once a day!).
Miele Cat and Dog Complete C3 Canister Vacuum
Pricey but mine is brilliant.
Dyson's are cheaper and now you know why!
Good luck
Apr 30, 2017 | Dyson DC27 Bagless Upright Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
My filter is always full of dog hair on my animal. What is causing this. I have to clean the filter each week . Dirt seems to always be trapped in the filter also.
I have same cyclonic as you.  I also have a Miele Pull-along.  I use the cyclonic for fine dust after picking up the hairs with the Miele.
Much quicker in the long run.
Otherwise I would waste a lot of time cleaning out the Dysan Cyclonic.
Feb 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My wind tunnel had a lot of dog hair at the intake hole from my renter that used it. I was able to remove it, but is it possible there is hair up inside beyond the hole & how would I remove it? it is...
I have an upright Dyson Cyclonic.  Because I have dogs, I also have a Miele Pull-along.  I use the cyclonic for fine dust after picking up the hairs with the Miele.
Otherwise I would waste a lot of time cleaning out the Dysan Cyclonic airways.  I usually use long nose pliers to get the ball out and then I use my Miele to **** the rest out of the Dysans airways!!!
Jan 16, 2010 | Hoover U5453-900 WindTunnel Supreme Bagged...
Hoover suction
I had a fur ball stuck in the pipe.  I took the end off and used a broom stick to clear it out.
Jan 13, 2010 | Miele Cat & Dog 326i Bagged Canister...
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele Cat & Dog Vacuum
doubt it. could be dangerous to use. (had one burn up due to this)
Apr 23, 2007 | Miele Cat & Dog 326i Bagged Canister...
VAX Appliances 2000 Canister Vacuum Logo
144 people viewed this question
Top VAX Appliances Vacuums Experts
richie46
Jim
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
