Question about Excelstor Technology J880 Hard Drive
Can we use Excelstor Gstor as a Slave Drive? If yes, how? What is the jumper setting required?
  • 32,281 Answers
To configure the hard drive as a slave drive, you need to set a jumper on the hard drive to SL (slave)
The other jumper settings are MA (master) and CS (cable select).
Posted on Mar 20, 2011
How to set jumpers on a hitachi hard drive
Use the above diagram to set the HDD in the required mode.
For more details on Master and Slave modes please use the below link
http://www.ehow.com/how_6031_change-master-slave-designation.html
Aug 18, 2011 | Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
Jumper settings wd1600
yes, you are correct.
Feb 20, 2009 | Maxtor Hard Drive
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
Hello
Not met this drive, so not sure whether this is a drive issue or a Windows issue.
If Windows in showing you as not authorised, it could be a permissions issue - you can try starting in Safe mode, logging in as an account with administrator rights. Then go to properties on the drive and take ownership of the drive and all subfolders, so that you can then set whatever permissions you wish.
If it's drive-specific, I can't help. Sorry.
Sep 02, 2008 | Computers & Internet
How to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Feb 19, 2008 | Acer Aspire™ T180 PC Desktop
Cannot get harddisk
check both hard drives for jumper position. A typical layout will be: master jumper in master position (see label on back or top of drive), then slave drive jumper in slave position. These jumpers are small and sometimes require the use of needle-nose pliers. Also, the data cable issue: A typical dual drive cable looks like one connector that is physically at the end of a cable yet farther apart than the other two. This gets connected to the motherboard. At the other end of this cable, you will see a connector (for master drive) and nearby, another connector (for slave drive). If your drives support the CAS mode (cable select), then it is irrelevant which connector these drives belong to (assuming you use the 2 closer connectors). If not, it is is imperative that the drive jumpers be properly positioned as described above. Finally, if the above steps were followed and still same problem, then change the BIOS setting from AUTO to forced type. Some BIOS's require the CAS mode to be present on both drives. This can get complicated, but simply write down the settings from each drive (ex: cylinders, sectors, heads...) and then type in these settings at the BIOS screen.
Jul 25, 2007 | Asrock P4I45GV R5 Motherboard
Can't See HDD in Windows Explorer
Afraid Excelstors hard drive repair tool requires the drive to get wiped to fix the errors not like seagate or western digitals, only thing worth trying is put in a windows xp disc and boot off the disc, Press R on the first screen to do a repair in like dos mode. it will take you into a black screen with a dos prompt, type this in CHKDSK C: /R then press enter it will take about 30min-1hr but has a good chance of getting the drive to read.. once complete take out xp disc and restart pc all the best John
Sep 18, 2006 | Excelstor Technology J840 Hard Drive
Excelstor Technology J880 Hard Drive Logo
534 people viewed this question
Top Excelstor Technology Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
Mohammed Ebrahim M
Mohammed Ebrahim M
Gerard McHugh
Are you an Excelstor Technology Computer and Internet Expert? Answer questions, earn points and help others
