Hi, Have a Hitachi 42PD580DTA out of warranty. Will no longer get digital channels. Will work through a set top box. Tried Resetting Factory settings in DTT menu. Is it worth fixing? Someone said to replace the motherboard. Is this expensive? Can I do it myself? Where would I get one? Kelly
5 Suggested Answers
SOURCE: Remote Control-reset to factory settings
hi,,., i saw your concern... i worked for a big company whose supporting tv remote and universal remote... we reset remote by removing the batteries and by pressing all of the buttons twice (take not each and every button) by doing this it will discharged the power consume in the battery. and also check if there is a jammed or stucked button, or check if there will be a Function button... hope this may help
Posted on Feb 07, 2008
SOURCE: Lost the digital TV viewing
There's a button stating DTT/TV and I didn't realise that they were 2 options. That's that. I had a stupid moment!!
Posted on Jan 20, 2009
  • 40 Answers
SOURCE: trying to set up Wii console with Hitachi
You should have various input connections on the back of the tv. Use the red, white (audio) and yellow (video) connections. The remote should have a button that lets you select which input to use. After connecting the wii, turn it on and try all the input selections until you see the wii screen
Posted on Dec 23, 2009
caroldon
  • 17130 Answers
SOURCE: MY HITACHI PLASMA HAS NO
Check the power cord, fuse and switch
If Ok then please check the link below for help on repairing the power supply which might have failed in your TV.
So click on the link for power supply repairs
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jan 05, 2011
Hi I have a bush 3d smart TV 42inch bought only a couple of months a go, I was watching TV and it turnt off now it just keeps turning on and off the controller won't work, it won't change to any channel,...
Return to manufacturer or shop where you bought it and get a new set. The controller may need factory resetting but you don't have to put up with this and it is still under warranty.
Nov 28, 2014 | Televison & Video
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
No sound but i have a picture. I have tried changing channels, checked wires, tried different systems (Xbox, Wii, DVD player), and even check to be sure the mute buton wasn't hit
Tries tv and cables or satellites boxes unplug,replug it back like about an hour later.For the tv resetting itself back to the factory setting and those boxes updated it softwares.Go into tv menu go Audio Settting down to resetting to factory setting.By doing these steps have great chances to have ur audio back.
Feb 07, 2011 | Westinghouse Electric VR4085DF TV
Have sony kdl40ex400, tried initial setup to cable, must have done something wrong, can only get channel 4, even when not going thru cable box
Tries tv and the cable box unplug,replug it back like an hour later.The tv now resetting it self back to the factory setting.The cable box it resetting and upgrading it softwares.Now plug the tv back through the cable box again.Now go into ur tv menu select Cable and scan for Cable channels again.Now u should have all ur pay cables channels now.
Nov 17, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
I have a Hitachi 26LD8000TA LCD tv - does it have a built in digital tuner or do I have to get a set top box to receive the new digital channels?
The Hitachi 26LD8000TA is HD ready which means it has a digital tuner. You do not need a set top box unless you are getting your signal from a cable company that encrypts their digital signal.
Oct 09, 2009 | Hitachi 26LD8000TA 26 in. LCD TV
Teac hdb820
I just did a factory reset this morning and I had the same problem until I realised that you have to use the "Output" button to get the Video Outputs to DVI Digital (see page 17 of the manual), if that's what your connection is, then I could select "menu" and do a channel search. Hope this helps.
Mar 21, 2008 | Televison & Video
Loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Oct 21, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
