Question about Nikon D80 Digital Camera with 18-135mm Lens
Monitor does not stay on
I have set the monitor to turn off after one minute of inactivity, so it should turn on with the camera, but the monitor only turns on for the 3 seconds of image review after taking a picture.
I don't mind using the viewfinder, but seeing what my settings are onscreen is useful.
    An expert whose answer gotĀ voted for 100 times.
  • 216 Answers
The LCD monitor screen at the back of the camera does not display a live picture like many point-n-shoot digitals. It only displays after the pic is taken. Use the LCD on the top cover to check your settings. Please leave feedback if this helps.
Posted on Aug 02, 2008
Screensaver will not turn on after inactivity
This is an adjustment made in the control panel under I believe Display. From there you will have an option for Screen Saver. It should all be in there.
Jan 01, 2013 | HP w1907 LCD Monitor
Monitor won't stay on
The problem maybe with the settings in your computer. Check if the screen savers are off and also make sure that the computer doesn't turn the display unit off after some time of inactivity.
Apr 02, 2011 | KDS 2237MDWB 22" Monitor
Viewsonic monitor stays on for only 3-5 minutes and goes off . Then I turn it off an wait and it comes back on!!! what is going on??
I guessing that when you say "goes off" you mean it goes into power-saving mode? Assuming that you're working on the computer at the time (so it's not actually going to power saving mode from inactivity), this might indicate one of two things:
a) the VGA cable to the computer is not in a good contact with the monitor. This might happen if you haven't used the screws to fix it in place, just try to plug it fully in on both ends (computer and monitor). If the monitor sees to VGA signal, it goes into power saving mode automatically.
b) there's a problem with the monitor that builds up after a few minutes. When you turn it off, it "cools down" and can be used again. If that's the case, you should take it to a dealer's shop and have it checked (or replaced if it's still under warranty).
Mar 13, 2011 | ViewSonic Computers & Internet
On dual-monitor setup after period of inactivity flatron stays dark and fails to respond, while the old hitachi crt responds immediately
try resetting the setup i mean setting it up again also what happens when you turn the monitor off and back on
Apr 05, 2010 | LG Flatron 295LM 22" LCD Monitor
My computer keep shuting saying monitor going to
start button >settings >control panel > Power Option > set time for monitor to sleep if inactive...if you dont want the computer to sleep go up to the hibernate tab and uncheck it. If you want the computer to stay on regardless, move all drop down menus to "never" instead of a time.
Sep 01, 2009 | HP w1907 LCD Monitor
Monitor shuts off after inactivity
Hi maggieis,
I wouldn't worry about your monitor powering off after 30 min. It's just responding to the power management settings that are configured from within Windows.
These settings can be changed so that your monitor always stays on (if you want) but the current setting is set to help save energy by turning off the monitor when no one is using the computer.
So, no worries...that's just normal Windows behavior.
Hope that helps,
Nov 19, 2008 | Westinghouse LCM-19v1 Monitor
Camera will pan to an area but will not stay there.
Most PTZ cameras have an "inactivity" setting. If no command inputs are entered into the keypad for a programmed amount of time, typically between 30 seconds - 5 minutes, the camera will return to it's pre-set position. You should be able to turn this off in the camera programming. A good way to test to see if this is the problem would be to point the camera to an area, then make very tiny adjustments to the direction every 2-3 seconds. If the camera does not go to the pre-set, then inactivity is turned on. Also, point the camera to an area and time how long before it returns to pre-set. If it is the same amount of time on every occasion, this would also indicate that inactivity is turned on.
Let me know if this does not work, or if you don't know how to access the programming menu -
Nov 18, 2008 | Pelco ES3012 5MLZ30PW Esprit High Res...
Monitor takes a long time to wake up
replace 2 caps 1000uf each 16 volt
I purchased 5 of these babies (new) at the same time and 3 of them had this problem
Sep 25, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Nikon D80 Digital Camera with 18-135mm Lens Logo
111 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
