Question about ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3 EAH5450 SILENTDI1GD3 Video Card
When connected to my Philips 47PFL7422 tv via HDMI cable I get video but no audio. When connected via the VGA port I get both audio and video,
  • ASUS Master
  • 11,800 Answers
The VGA cable is strictly just for video so the sound is received thru an analogue (RCA) cable. HDMI is an combined digital link but the video card delivers only the video - you must tell the tv from where to get the sound (use the analogue connection already in place) This is done in the menu.
Posted on Mar 21, 2011
I have connected my laptop to my element tv via vga cord;sound is comin frm laptop..want the sound frm TV; THEN, I have a headset/microphone ... can I connect my headset/microphone to the TV?
If you need to get sound from your TV, you should have a sound input socket in your TV. If you have that you can connect an audio cable from your sound sound socket to your TV.
The second option is that your laptop and your TV should have HDMI ports. If its there, you can use an HDMI cable(instead of VGA cable)to connect the two. With HDMI cable, you will get both video and audio through that single cable.
If you need more help please let me know
Jul 02, 2017 | VIA Computers & Internet
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Can not connect hdml wire to my philips led tv with my dell laptop. what to do
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters.
Check out this WEB site.
http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Mar 05, 2013 | Computers & Internet
How do I connect my Laptop Acer 5735 to my TV Sony KDL-40NX700, what kind of connection cables do I require?
If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Sep 10, 2011 | Acer Aspire 5735 Notebook
I have an older 2004 or so philips hdtv projection tv with the built in tv stand. i want to connect my HD cable box but there are no hdmi ports. and i buy a wire with the VGA on one end and hdmi on the...
Get a component video cable (blue, green, red) and a separate RCA audio cable (white and red) if your cable box has a component video output and the TV has a component video input.
If your cable box doesn't have the component output, you will need a converter to go from the HDMI to component video. Something like this: http://www.hdtvsupply.com/hdmi-to-component.html . There are other converters available if your TV has some other inputs available.
A cable that has an HDMI M on one end and a VGA M on the other will not work. HDMI signals from the set top box are a digital signal. The VGA port on the TV is set to read an RGB analog signal. (Similarly a component to VGA cable would not work since the RGB and PbPrY are not compatible.)
I hope this helps.
Sep 02, 2011 | Philips 60PP9363 60" Rear Projection...
I have a HP m7570n. How do I use a flat screen tv as a monitor
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
May 12, 2011 | HP Pavilion m7570n (EX331AA) PC Desktop
Hello, I was wondering, if there is any way to connect my computer, which is a Dell Dimension C521, up to my T.V., which is a 32 inch ilo. I have a Philips Video and Audio red white and yellow connector,...
Connecting a pc to a TV is quite simple. Your PC has either a vga out or HDMI port. Just get the right cable and connect to your vga port on the TV or HDMI port on your TV.
This way you can even have the two screens running, alternatively press Fn and the appropriate F key to switch off the laptop screen.
Your sound will still be thru your PC speakers.
Jan 10, 2011 | Computers & Internet
ASUS ATI RADEON HD 5450PCI EXPRESS21DDR3 EAH5450 SILENTDI1GD3 Video Card Logo
313 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
