ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
Posted on Mar 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound device driver problem - ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Anonymous
Level 3:
  • ASUS Master 32,281 Answers
  • Posted on Mar 20, 2011
Anonymous
ASUS Master
Level 3:
Answers
32281
Questions
Helped
7911821
Points
102259
Try installing the latest audio driver.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
1helpful
No sound driver
IF YOUR SOUND CARD ARE NOT DETECT
FIRST YOU USE KB888 UTILITY FOR DETACTION SOUND CARD
ITS UTILITY ARE FOUND YOUR INTEL945 ORIGNAL DRIVER CD ON SOUND DRIVER
IF YOUR SOUND CARD ARE FOUND BUT DRIVER ARE NOT
GO TO DEVICE MANAGER PROPERTY ON DEVICE HERE ARE SOME DEVICE ID CODE ARE DISPLAY COPY IT TO USE THIS SITE http://devid.info download suitable driver
extract your driver on any location
go to device manager click on update driver
advance and slect driver path and enjoy your sound and other hardware parts for use this best site
tip
My sound driver stopped working after working for at least a year.
Open Control Panel
open device manager
ensure that you have the proper disk to restore the sound device driver
delete sound driver
restart your computer
if the sound is not repaired, use the sound device driver disk to restore the device driver
on Jun 22, 2010 • Computers & Internet
1helpful
2answers
How to i instal sound drive for my pc?
Hello
1. Power on your computer. Ensure that there is a sound device installed on your computer. You can locate your sound device by right clicking on "My Computer." Click "Properties." Select "Device Manager." Click on "Sound." Your sound device should be listed. If there is no sound device listed, you will have to purchase and install a sound device before proceeding.
2. Insert the CD or floppy disk that contains the drivers for your sound device into your computer's CD-ROM or floppy disk drive. If you do not have the CD or floppy disk that contains the sound device drivers, there are websites such as Driver Guide and NoDevice that will allow you to download the drivers online for free.
3. Click on "Install Drivers." The sound device drivers will then be installed onto your computer. It may be necessary to restart your computer once the installation is complete.
4. Open your media player and play an audio file to ensure that your sound device drivers were installed successfully.
THANK YOU
2answers
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
1helpful
2answers
Sound driver
If you need sound drivers for your mecury P4VM800M7 Mainboard, download @ http://www.mercury-pc.com/downloads_list.php?productid=644
1helpful
No sound , sound drivers are working
Most common reasons for this trouble are:
  • Such kind of troubles arise after some device / software is installed which tries to gain control as default sound device.
  • Also while un-installation of certain softwares, some shared files are removed. At times some important shared file can be deleted which causes troubles with working of sound drivers.
  • While installing certain games, it tries to gain control of sound or video drivers and may accidentally harm these driver softwares.
Lets see the ways to fix such troubles
Step1 : First of all check what is your default audio device setting. For this, open Control Panel > Sounds and audio devices, open Audio tab as shown in picture below.
See that the Device selected is your sound-card or on-board audio device. It should not be blank or some modem device. Set the Default sound playback and sound recording device correctly from the drop down menu. If your device is not there in this list see the step 2.
Step2: If the step 1 is not successful, it means that your sound device driver software has become either corrupt or has been accidentally un-installed. In such case, install the sound driver from the sound-card/mother-board driver CD. You can also download the latest driver if you don’t have the driver CD. After you install the driver, restart your computer, and then check the settings as in step 1 again
2helpful
Sounds and audio devices not working
Sound and audio device is not working because of the following problems
1.Problem related with sound driver
Solution: Re install the sound driver from u r motherboard CD.If u use PCI sound card install the driver software from the CD given by the vendor
2.Inorder to check u r sound driver related problem.....go to...Device manager....> audio devices.....> if there any Yellow coloured question mark on the sound device problem related with driver software.
3.May u r sound hardware is not working.....if it is on board card then add any PCI sound card and intall the software from the CD u will get the sound
About sound device...
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
to make the sound driver work
you must first download the UAA driver on the above page
then go to device drivers and upgrade the sound one it will go on net to find and install them
2answers
No sound device detected..........
Go back to device manager. The devices that you see that have a problem. Right click on the device than un-install the device. You will need the motherboard's driver for these device. In order to find the correct device driver's I'll need the boards model number & any revision's. Than I can direct you to the correct download site. Above you state it's a Gigbyte. The more detailed information you post the better the driver.
2answers
PROBLEM IN SOUND DEVICE
What hardware device drivers should be updated? A listing and recommendation of computer hardware device drivers that should be ... A listing of computer sound card drivers can be found on our sound card .
Issues relating to msgrv32 Resource conflict or issue; TSRs or other running programs; Sound driver or sound card issues; Onboard sound or video issue; MIDI device or codec issues
POST troubleshooting steps. Bad or failing hardware device. Connections not connected or connected properly. ... if you press the power button and nothing happens (no lights, no sound.
Good Luck, Please dont for get to Vote/Thank You.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
