Question about Dell E2010H Monitor
Dell E2010H Wide screen monitor Screen has pink background ? After resetting to factory settings still the same ?
  • Dell Master
  • 32,281 Answers
It's a dell monitor e2010h and it starts up then runs post op then it goes into a black screen and a cursor
That is the computer problem, try booting in safe mode to see it works OK, if it does, you can try uisng system restore to take it back the known working date before the problem start.
Hit F8 key while booting up if you use XP.
XP: http://support.microsoft.com/kb/315222
WINDOWS 7: http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode
Aug 23, 2011 | Dell E2010H Monitor
Ratio on wide screen not correct photos appear "squashed"
Your screen resolution is not correct for the monitor. On Win XP just right click anywhere on screen background, and choose properties from the pop up men. In the tabbed window that opens choose the "settings" tab where you'll see a slider bar for "resolution". Try different levels till you find one you like, where round object appear round and not oval. In Vista or Win 7 when you right click the background, choose "personalize" and locate the resolution settings there.
Nov 10, 2010 | Dell Computers & Internet
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Pink Screen
Probably the color temperature setting or some other color settings - since you didn't specify your monitor's brand and model, it's hard to guess.
Anyway, most monitors have a "Reset to factory defaults" feature - you may want to make use of this...
Mar 10, 2010 | Dell Computers & Internet
Have a VG2230wm wide screen and the image trembles and bounces slightly, and the color is going from white background to pink. What would be causing this? The monitor is about two years old, it is set at...
This is due to a bad pin or bent pin or a bad connection isde the monitor or can even be a bad signal cable. Check all of these when in doubt check the solder points inside the unit.
Thanks hope this info helps please rate...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 21, 2009 | ViewSonic VG2230WM LCD Monitor
Computer Screen
Check the screen settings resolution in your computer
Start >> Control Panel >> Display
Reset your monitor to factory settings.
Oct 10, 2008 | Computers & Internet
Dell E2010H Monitor Logo
147 people viewed this question
Alun Cox
