Question about LG WM-2277HW Front Load Washer
My machine will not pump water, and I cannot remove the load that is currently in there
  • 3,018 Answers
If it's not draining you have to manually drain the washer by pulling the drain hose out. You can also pull the drain hose out of the drain pipe it drains into and lower it into a 5 gallon bucket to get most of the water out without such a mess.
Posted on Mar 20, 2011
Why does washer stop agitating after few minutes?
Check for something caught in the pump or under agitator.
Check that the belt underneath is free running.
This fault is usually associated with excessive current & the motor going out on the auto reset overload.
Could be motor trouble, starting capacitor (If fitted) or the timer.
Jun 29, 2015 | Kenmore 24032\24036 Top Load Washer
Water pump leaks
Remove back cover of the washing machine.There are two rubber hoses connected to water pump remove them.and careful detatch live wire from pump motor.There are either 3 or 4 screws connecting the pump onto the washing machine body unscrew them,and the pump should be removed easy then.
Jan 05, 2014 | Estate Top Load Washer
Maytag mav6200 top load washer leaving an inch water in tub, disconnected the water pump to remove a small stuck piece of metal when it was squealing loud, replaced everything and now it leaves an inch of...
The piece of metal you removed came from around the pulley assembly on the pump? There is an updated drain pump that is for that model and should be replaced. The original pump was a bad design and fail quickly. Here is the new pump that I would replace it with and all will be good. It has a higher volume that it will pump out. The reason the current pump is leaving water is that the timer is finishing it cycle before the pump is able to remove all the water.
Please let me know if I could be of further assistance to you.
Richard Roth
Oct 13, 2012 | Washing Machines
My washer is making a humming noise and will not run. there are currently clothes and water in the washer
remove 4 screws on the rear panel and then remove the cover, you can see the drain pump remove both hoses on the pump,it is probably plugged up,if it is they wont drain or do anything
Apr 30, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Will not drain water. tried testing pump. No sound from pump. we think it is most likely the pump, but how do we make sure that is it??
unplug first be very careful working with live current,,,remove leads from pump put unit in drain cycles plug unit in ,,than test for 110 volt at pump connection..if you have 110at the connection you have a bad pump..good luck
Sep 02, 2011 | GE WPGT9350C Top Load Washer
GE front load washer is not draining after spin cycle
The draining is controlled by drain pump in the washing machine. If the drain pump is clogged or got loose then water will not drain properly and this problems will occur.Remove the drain pump and drain hoses. First thing you can do is take the drain hose and blow into it and check if its getting blocked.If the air is passing through the hoses then loosen the hoses to the pump. You might want to get some pinch off pliers to save water from going ever where or a shop vac to **** out the tub. If the pump is getting warm current is flowing to it and propeller is jammed more than likely. The front should have a couple of 1/4 screws at the corners on the front should pop after removing them. If you require parts then you can buy them from www.repairclinic.com Thanks. you can rate this solution and show your appreciation.
May 17, 2010 | GE WSXH208A Front Load Washer
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
I removed my pump because water would not drain. i plugged up and pump still does not move, but winding sound is present. Does the motor require a load to run? And does this mean the pump is bad?
Hi, water pump doesn't require load to run, check motor (coi)l with ohm meter (multi-tester), check for continuity, good job, removing pump and cleaning it, it's a commom problem with washing machine. it's possible your pump motor burnt out, two things you can do, to check pump, (1) two wires that you remove from pump motor, put volt meter,put power to machine, be careful, check for correct voltage, if voltage is present, and pump didn't work, then water pump motor, burnt out (2) remove water pump, make extension cord, plug directly to receptacle, if it's good, it will run, if it didn't run, replace it, good luck
Aug 08, 2009 | Whirlpool LSR6332K Top Load Washer
Lwd70aw washing machine water pump
your pump been leaking water and has the pump rusted to it ,,,,, if the clips are removed the you will just have to pry and break pump loose to remover ,,,, clean the motor shaft good before installing new pump
Oct 16, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Calypso won't drain
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
207 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
