Question about ASUS P5PE-VM Motherboard
Monitor appears no signal, monitor tested and ok, hard drive ok...i think mother board is the problem...i don't want to buy a new one... accdg to some the mother board is already phaseout...how about my memory ddr 400 and processor is a core 2 duo...it is still in good condition...any latest asus mother board comptble with core 2 duo and memory ddr400 (3)
  • ASUS Master
  • 32,281 Answers
An alternative is to install a video card in the AGP slot, you may need to disable the on-board video in the BIOS.
Posted on Mar 20, 2011
Computer powers up, MONITOR says no signal
had same problem...re-install windows ...bad drivers and such
worked fine after that
Mar 31, 2014 | Gateway Computers & Internet
Was workin ok but no signal imput now
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
If i open the laptop the illuminated lines appear on the screen and i cant see a single thing and i hear the sound of hard disk which is spinning but the blank screen irritates me what i do
It's possible your laptop screen is going bad. Here's something you can try. Get an old monitor from a desktop. Power it up and hook it into the video port in the back of your laptop. Hit the Fn key and the F7 key at the same time. This tells your laptop to send the video signal to the port in the back of the laptop. If the computer works with this new monitor you may want to take your laptop into a computer repair store to have the screen replaced, or if you want to replace it yourself I can give you some advice on how to do that. If the computer doesn't work with the new monitor you may have a hard drive or mother board problem. The first thing I'd try then is to reboot the computer from your CD rom drive using a recover disk. If you can get it to boot ok from the CD rom it's probably a hard drive problem. You might be able to fix this problem by reloading windows.
Jul 04, 2009 | Dell Latitude D630 PC Notebook
On screen display keeps appearing on, and usually
hi..i think you have a problem the CPU/Computer that's whystays on screen for so long.1st step check the IDE cable connection form the mother board to Hard Drive and 2nd check the memory or check all hardware`s.Good Luck and Have a nice day
Jun 17, 2009 | HP mx705 17" CRT Monitor
Mothe4r board problem
Nothing you can do except replace the motherboard or buy a new computer.
It might be cheaper to get a new computer, especially if your computer is more than a few years old.
You can transfer the hard drive, video card, the monitor etc. to the new computer if those components are OK.
May 27, 2009 | Acer Aspire 3680 Laptop
I think I my have busted my mother board
FIRST WILL MB SUPPORT THAT MUCH RAM?(2). ARE SATA DRIVERS LOADED?(3)IN BIOS IS BOOT ORDER SET CORRECTLY?CHECK MB SPECS AT FACTORY WEB SITE.I BELIEVE MB STILL GOOD. CONFLICT PROBLEM MAYBE A JUMPER?RICHARDM69
Nov 20, 2008 | ASUS K8N-LR Motherboard
Boot up problems
The beeps can be either video or memory. Most likely it is memory. Check the memory.
Thanks,
Lolita
Apr 09, 2008 | Mach Speed P4M800 (890552603480)...
IBM Mother board mlack out
just buy another power supply with a higher power for the problem is not on your computer but on the power supply,then try to plug it in a 220v voltage regulator,but i surely recommend that you'll buy a new power supply ok
Apr 08, 2008 | IBM 486DX 80486 (32G4144) Processor Board
ASUS P5PE-VM Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
