Question about Siemens Refrigerators
I have go Siemens Fridge Freezer KG34UM90, when it connected whole power at home goes off what could be the problems
5 Suggested Answers
  • 13 Answers
SOURCE: i have a siemens frost
Check to see if the fan the blows cold air from the freezer compartment to the refrig is (a) not blocked in either the freezer or refrig, or (b) not working at all. Replacement of the fan is likely very inexpensive - cheap parts, and a possible DIY if you can use a screwdriver and read an exploded view in the on line parts manual for your model.
Posted on Oct 26, 2008
Sebin
  • 712 Answers
SOURCE: its a side by side Siemens KA62DP90 GB
This may be due to any small leaks in the water supply line going to the ice maker. The leak caused water to flow outside and a part of it was frozen by the freezer. That is what happened. It is having only a simple repair to replace the pipe. But since this one is new, you may be well inside the warranty period. So don't take any risk. Just contact your dealer. Else it may spoil your warranty agreement.
Posted on Apr 22, 2010
BIKER T
  • 909 Answers
SOURCE: fridge compatment not cooling
If freezer compartment is cold and fan is working, do a 12 hour defrost and all should be ok.
Posted on May 21, 2010
Testimonial: "That was the problem - thanks for the tip, spot on !!"
heatman101
  • 43501 Answers
SOURCE: My Siemens fridge freezer model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 04, 2011
What is the optimal temperature setting for the fridge and the freezer unit for a Siemens fridge/freezer
settingmode between 3 and 4 can be a good choice if the environment temp outside is around 14 degrees
Jan 07, 2017 | Siemens Refrigerators
How do I remove the fan cover on my Siemens fridge freezer?
First, unplug power supply. If you can see the fan, brush any loose dust/debris into some plastic container for disposal then vacuum. From what info you provide, it appears access to fan blades may be from rear of refrigerator and may not be worth the effort to disassemble to clean. You might find that one of the many household multi-surface spray cleaners will adequately address problem. If not, the cleaner used for silk plants may work. Otherwise, find your product's service manual and follow its guidance for accessing the fan.
Feb 18, 2015 | Siemens Refrigerators
Why does Siemens KF57U56/16 Freezer works fine, but not fridge?
Check the thermostat adjustment in the fridge section if right up replace the thermostat.
Aug 28, 2014 | Siemens Kitchen Ranges
Siemens KG39NA00GB fridge freezer auto-defrost problem.
When you defrosted manually, did you get a lerge amount of water down the back of the unit? If not. the drain is blocked. Also clean and clear the condenser
Apr 24, 2012 | Refrigerators
Its a side by side Siemens KA62DP90 GB freezer/fridge.it is new, i just turned on the fridge yesterday and also the icemaker and found my whole freezer frozen the next morning with water seeping out.
Apr 22, 2010 | Siemens KI20R440 Refrigerator
American fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Apr 03, 2010 | Freezers
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Refrigerators Logo
Top Siemens Refrigerators Experts
marlin siecinski
David Ellis Rhea
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
