Question about Philips Televison & Video
Philips Cineos model no: 32PF9631D/79 - Sometimes when you turn the tv on there is sound but no picture. Now we have sound but the picture has vertical pink lines. Thanks for your help
5 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Posted on Feb 18, 2008
SOURCE: Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Posted on Apr 03, 2009
SOURCE: Sound but no picture Philips 42PFL9632D/79
I had the same problem, no picture, contacted Philips who put me on to NESN (0845 610 4105) for local agent, they diognosed a falty "Inverter Board" all costs will be £365as the set is only 18 months old Philips are looking into some compensation towards the costs. I await there reply. Looking at several web sites worldwide this seems to be a problem with this set between 12 & 24 months old.
Posted on Jan 17, 2010
panchal643Ja
  • 243 Answers
SOURCE: vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Posted on Jan 21, 2010
Lg tv hts9800w
What have you tried? Is there any sound at all?
Oct 29, 2012 | Philips Cineos HTS9800W System
My TV Philips cineos 47pfl9632d/10 has a problem not working There is a sound but not picture completely blank screem
im having the same issue instead of soldering im just going to buy the power board they are only 34 dollars in shop jimmy cheap enougth
when i plug mine in i get no lights butspeekers make a brief noise then go quiet screen dosnt even light up was working 8 hours before so after reading all comments from this site im going to replace the power supply board will post if it works my model is 47PFL9632D/10 for future readers
Dec 27, 2010 | Televison & Video
Philips lcd Cineos 42PFL9732D/10 tv will not turn on and a red light keeps blinking. Followed the manual's instructions to switch off and unplug the cables but nothing has happened. Can you help please ?
Take the tv aparts and replaced the power supply board will solved this problems.The board where the power a/c cord plug into it,that the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 17, 2010 | Philips Cineos 50PF9531 50 in. Plasma...
I have a philips tv, its a 42" cineos, i have sound but no picture, can you help, or tell me the tv is any use, its only two and a half to 3 three years old
There are many issues that can cause that type of problem. Just take it in and pay the low cost for the estimate. It is well worth the money to do it that way.
Apr 10, 2010 | Philips Cineos HTS9800W System
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
TV MODEL 32PF9631D 2 YEARS OLD INTERMITTENT FAULT BECOMING MORE FREQUENT - PICTURE DROPS OUT LEAVING BLANK BLACK SCREEN (ALL CHANNELS INCLUDING FOXTEL) BUT SOUND REMAINS. TURNING TV ON AND OFF WILL...
You have problem with the power inverter, in you tv it might be part of the power supply, in which case you will need just one board. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Televison & Video
Phillips cineos 52 inch have sound but no picture
i have a 52 projection tv phillip and the pic is off you see three images on the bottom nice pic in the middle and on top a little off.so what is the problem
Jul 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Cineos LCD TV doesn't turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 18, 2017 | Televison & Video
Lip sync playing ordinary tv
you need to have a sound speed equalization higher frequencies travel slow,
if you can buy a AV/RF CONVERTER the problem can finish
AV be connected to devices and RF to tv
this can over come that problem
Oct 07, 2008 | Philips Cineos HTS9800W System
Sound and picture
Check that you have connected the component video lead to the correct sockets in both the TV and the HTS9800W.
There are two sets of Phono (cinch) connectors, which are grouped together.
Red / Green / Blue - Component connectors - video only
Red / White / Yellow - Stereo audio and composite video connectors - audio and vide
If you have inadvertently connected the red audio connector to the red component input on the TV, it would cause similar symptoms as you describe.
Jan 13, 2008 | Philips Cineos HTS9800W System
Televison & Video Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
