Sir, I hav canon ip1880 pixma. I have already refilled the black cartridge and is working fine. my question is that can I refill the colour cartridge with black ink in all its three compartments instead of colour inks. thank u. Dr Prasad
  • 32,281 Answers
I would not advise doing that. Once you do this you could have unexpected poor print quality.
If you only want to print black documents then I suggest you purchase a laser printer, these printers are not expensive now and the cost to per page is cheaper than inkjet printers and they do not suffer from block inkjet nozzles.
Posted on Mar 20, 2011
After refilling he black an coloured cartridge, i always get the error E 5 and the lights B and C are flashing orange. I already changed the cartridges several times.
Using refills and non-canon inks can cause issues with the printer. You can damage the print head and fill up the waste ink tank faster then needed..
Best of luck..
Dec 03, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Ink
Better not to refill. Better buy a new original Canon cartridge. The reason being that some of the newer printers have sensors which can detect refilled cartridges and will cause more problems later.
Nov 07, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Working with cannon ip 1300
You need to have a black and a color cartridge installed to use your printer. That doesn't mean the color cartridge has to be full. You can have an empty color cartridge in the printer and it will work as long as the electronics are good on it so the printer can recognize it's there. You cannot refill these cartridges yourself. Your printer remembers what cartridges have been in it so that it can reject refills (it sees the same serial number twice and catches you trying to not give Canon their money). You can use refills, but you need to get them from a refiller with a high turnover of cartridges so you don't get the same serial number twice. I recommend Cartridge World stores as they have high quality refills with a 100% satisfaction guarantee.
Sep 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Refilling canon iP 1880 color cartridge
Insert a fine needle through the hole and when the ink sticks to the needle withdraw it and rub on a white cloth and identify the color and mark the holes accordingly.
Jan 23, 2008 | Canon PIXMA iP1600 Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
82 people viewed this question
k24674
jasbo
jasbo
