Question about Sony Audio Players & Recorders
Sony cdp-r10 shipped from Tokyo Japan was damaged by Fedex it weighs 67 pounds opend up to view inside , this model has a fixed Laser , the cd holder only moves about 1/2 inch twards the laser stops then returns that is all it dose now
    Brigadier General:
  • 3,513 Answers
Since you have received the part damaged. All you need to do is to call their support number and ask for a replacement as it was not your fault. I would suggest do not try to troubleshoot and compromise on the broken cd holder at this point of time. Please find Sony's international support numbers where you can call and log your case at the earliest.
http://www.sonymusic.com/page/contact-us
Thank You
Posted on Mar 20, 2011
Tip
Radiation Monitoring in Japan Click the map below to travel to the...
Click the map below to travel to the RadiationNetwork.Com 's Japan Radiation Map.
The RadiationNetwork.Com 's Japan Radiation Map is not currently receiving data from its Tokyo network member.
Follow this link to view The RadiationNetwork.Com 's National Radiation Map for Japan.
___________________________________________________
Please Donate to Help Japan
on Mar 16, 2011 | Computers & Internet
I have a sony cdp cx355 that seems to have a disc stuck and the door will not open to remove it. How should I proceed?
You have to remove the cabinet to expose the inner workings. Once inside, you should be able to see the stuck CD. Be careful to avoid damaging any parts of the player mechanism as you work the CD back into the carriage. You may find that once the CD is back in place normal operation resumes.
Sep 04, 2016 | Sony MegaStorage CDP-CX355 300-Disc CD...
Cd player skips, shoudl I be cleaning inside and how do I do that? Sony cdp-cx205
I would try a cd cleaner cd - they normally have tiny brushes on the CD itself, which when used brushes against the laser lens.
I have opened one up before, they do get dusty - so if you really want to give it a good clean I would open it (remove the 6 screws putting them somewhere safe) and use a can of compressed air to blow out any dust.
There is a fair amount of grease inside which may collect dust if blown about.
Good luck.
Jun 12, 2011 | Sony CDP-CX210 200-Disc CD Changer
Where can I get the "rubber band" that drives the
I think you are looking for tray loading belt as it is marked in below exploded view taken from service manual of CDP-C505
Belt part number is as follows:
492639901 ... Belt Square
It is available with PartStore.com for $5
Hope these info will help you, let me know if you need service manual copy.
Thanks.
Nov 27, 2010 | Sony CDP-C505 5-Disc CD Changer
ALL SEEMS FINE BUT WON'T PLAY DISCS. FLASHING BLUE LIGHT INSIDE.I GET "LOADING ERROR" ON SCREEN, AFTER A COUPLE MINUTES. SONY CDP-CX400
I would suggest taking a can of compressed air to the disk tray to ensure the laser is clear of all possible debris
Mar 30, 2010 | Sony CDP-CX400 400-Disc CD Changer
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Jan 15, 2009 | Sony CDP-CE375 5-Disc CD Changer
Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Dec 27, 2008 | Sony CDP-CX53 51-Disc CD Changer
323 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
