Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
My Fisher Paykel dishwasher frequently turns itself on and usually when it does this it keeps turning back on after I turn it off. It will only stay off if I leave the door open. This is not always but often. Please help. Thank you
  • Fisher and P... Master
  • 3,247 Answers
Most likey there is a back flow of water from the kitchen drain which is causing the drain pump in the drawer to start in order to empty it.
Check the drain hose is connected according to the installation instructions.
If you do not have one, then download from this site. If you are running a garbage disposal unit in sink then make sure it is operated regularly.
Posted on Mar 20, 2011
F9 fault code
This is a controller fault and depending on the conditions of when it occured, may need replacement of controller itself or some sensor which feeds signal to the controller. Usually if fault keeps repeating or is permanently on and turning mains power off and on makes no difference, then you will need a technician to look at it.
Oct 15, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Cannot turn my fisher and paykel dishwasher off..keeps beeping and motors are running in both draws. I have taken the bottom draw out and it is dry.. I can only turn it off if I turn the house mains off...
I am assuming you infer that the bottom of the dishwasher is dry when you took the bottom drawer out. This means the floodswitch located on the power filter board at the bottom of dishwasher might be faulty. Do you get any Fault code on the display.
Apr 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My single Fisher & Paykel dishwasher drawer DS603I (Integrated Panel) turns on by itself even after turning off the light switch that controls both units that sit on opposite sides of the sink. The...
Yes ,you may be able to restore function by completely drying the area and PC board located under drawer.Use a hair dryer.
However , you will still have a leak and the problem will return.Usually the leak is drawer lid not closing properly. Suspect lid actuators have failed.Very common.Or some kind of obstruction.The drawer can be removed easily by removing 2 large plastic scews at drawer front.If lid actuators have never been replaced go ahead and do that.It is normal for other drawer to work fine.
Hope this helps you
Aug 16, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is model DD603 and it turns on by
There is a water leak in the bottom housing and a leak sensor detects to give a F1. Pull out the tube and put your hand in the front from the left ( only on this side has enough room to access) with the small towel to dry out the water on the bottom housing. After dry out, unplug the power for at least 24 hours so the sensor can be dried out and reset. However, make sure to fix the leak from the top seal, otherwise, it keep happening.
Oct 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Turn on and off buy it self
If a Fisher & Paykel dishdrawer is having a problem, it will usually display a fault code beginning with a "U" or an "F". "U" codes are usually solvable by the owner by checking the definition in the owner's manual. "F" codes usually require a service technician. I can tell you from experience that if you have no idea what to do, you should leave this one to someone who does. It's very easy to cause more damage by trying to disassemble it incorrectly. Also, the DD603 utilizes a "smart tool" that enables a technician to use a laptop and F&P software to diagnose the problem correctly.
Apr 25, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishwasher
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Oct 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
1,412 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
