Question about ASUS Eee PC 1000HE Netbook
Hi... I have Asus EEE PC 1000HE. Its about 1 and 1/2 years old. I have two OS simultaneously installed - Windows XP (the original provided by Asus regularly updated) and Ubuntu (insatlled by me). My problem is : 1. In Windows XP, the screen resolution keeps changing through its all options after every few seconds/minutes automatically. These changes become more frequent when the battery is on charge/ connected to the power. Earlier, the problem was only when the netbook was put on charging and not when it was on battery. (serious problem - makes netbook unusable) 2. In ubuntu, at times (very infrequent though), the OS logs me out automatically usually when I am typing or using the keyboard and not if I am just viewing or using the mouse pad. ( not so serious - as work can be done ) I could not find any solution over net or any forum. Some help in this regard will be very very helpful. Thanking in advance.
    Top Expert:
  • ASUS Master
  • 52,509 Answers
No computer I know of is designed to have 2 operating systems running at the same time th will cause conflicts continually
Posted on Mar 10, 2017
  • 6 Answers
SOURCE: Desktop theme changes at startup
That's not supposed to be a problem... When you log in to your account windows loads your personal settings, as well as other programs, so it's supposed to take time. Windows probably has the theme set on default so it would show that while your settings are loading. That or you've got a virus... But... if you think your computer is unusually slow then that's a different problem. Try cleaning up your hard disk space and doing other sorts of stuff, like scanning for viruses to make it run faster.
Posted on Jan 18, 2009
camille zar
  • 95 Answers
SOURCE: I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
  • 733 Answers
SOURCE: how do i upgrade the OS of eee PC 900A
download the image of ubuntu put it on a stick here you have two option uninstal the old OS or update if you want to update:
To upgrade from Ubuntu 9.04 on a desktop system, press Alt+F2 and type in "update-manager -d" (without the quotes) into the command box. Update Manager should open up and tell you: New distribution release '9.10' is available. Click Upgrade and follow the on-screen instructions.
To upgrade from Ubuntu 9.04 on a server system: install the update-manager-core package if it is not already installed; edit /etc/update-manager/release-upgrades and set Prompt=normal; launch the upgrade tool with the command sudo do-release-upgrade; and follow the on-screen instructions.more info on:http://www.ubuntu.com/testing/karmic/alpha1
Posted on Nov 24, 2009
kitt98
  • 26 Answers
SOURCE: i can't turn on my FN Key for Eee PC Asus 1000HE
um im pretty sure you have to hold it down
Posted on Jan 15, 2010
dj_relly999
  • 4070 Answers
SOURCE: ASUS Eee PC running Ubuntu
Hi! Please check the motherboard for blown or corroded capacitors. If the capacitors are faulty it can result to a sudden reset or no boot at all. YOu can determine a blown capacitor if it has a whitish powder on the top or theres a leak on the top. Once replaced you'll be good. Hope this helps and have a good one!
Posted on Jun 02, 2010
My asus eee pc says i have \windows\system32\config\system missing or currupt what ca i do
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 28, 2013 | ASUS Eee PC 1000HE Netbook
Driver of asus eee pc 1000HE
Hello download here at ASUS:
http://www.asus.com/Eee/Eee_PC/Eee_PC_1000H/
But here is no other files than bios and the manual.
Try using windows update.
Good luck
Nov 04, 2012 | ASUS Eee PC 1000H Laptop
Asus Eee PC 1005HA wontl load OS
what key do you see during the boot up process
you should see a certain key it will be very quick you might have to restart a few times to get a good look
try pressing the delete key
hope it helps
Apr 09, 2012 | ASUS Eee PC 1000HE Netbook
I had to reinstall driver (synaptics) on my recently bought asus u36sd since i managed to delete the driver while removing bloatware with a software. I did get my scrollfunction back but two finger- and...
Hi Ali.
you could try this or go to the link at the bottom and have a read up of what else you could try.
Push the computer's F9 button until the Recovery System window appears. Choose the option for Windows Setup and select Recovery. You should see a message disclosing that you will lose all your files in the process as the Recovery puts the machine back to its original factory settings.
How to Restore an Asus Eee PC Netbook ' eBay
www.ebay.co.uk/gds/How-to-Restore-an-Asus-Eee-PC-Netbook-/.../g.html
asus eee pc 1000he netbook restore factory settings Google Search
Nov 04, 2017 | ASUS Eee PC 1000HE Netbook
I have had to install windows xp professional on my eee pc 1000HE after i caught the xp antivirus virus and have now got a problem trying to find drivers to set up the internet on it as it doesnt have a...
go here http://support.asus.com/Download.aspx?SLanguage=en&m=Eee+PC+1000HE&p=20&s=1
all your drivers for xp can be found there, you will have to download them onto a usb flash drive and transfer them over to your Eee pc to install them
May 15, 2011 | ASUS Eee PC 1000HE Netbook
My webcam (Asus eee pc 1000HE) is not working after reformatted, i cannot see it anymore on MY COMPUTER, which is supposed to be there like before it was reformatted.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 07, 2011 | ASUS Eee PC 1000HE Netbook
Asus eee pc will not start it gets blue screen of death and safe more or nothing works
Re-image the Hard-drive. Put in the OS disk and boot from it and make sure you delete the old partition.
Nov 02, 2010 | ASUS Eee PC 1000HE Netbook
I have netbook Asus Eee and id freezes at "welcome" from windows.
go into safe mode and do a system restore to an earlier date ie: the last date it was working ok.
hope this helps.
Apr 27, 2010 | ASUS Eee PC 1000HE Netbook
Windows could not start because of a missing or corrupt file
Hi there please try these mentioned below.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Mar 27, 2010 | ASUS Eee PC 1000HE Netbook
ASUS Eee PC 1000HE Netbook Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
