Question about Sony BRAVIA KDL32V5500 32 in. TV
I have a Sony Bravia kdl 32w5500 and it periodically switches itself off whilst watching programmes on one particular channel (WIN TV AUSTRALIA). It goes into a kind of sleep mode or something and sometimes also switches off completely. When it first loses picture, and sound, the green light is on and you can change channel and the picture and sound comes back but when you go back to WIN TV it again switches of picture and sound and eventually the whole set, if left on WIN TV. The remote channel select button can be used to switch the set on at his time aswell. The set is 15 months old and has done this since three months old and then it was dine for another 9 months and now it has started doing it again.
HDTV GURU
  • 261 Answers
SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Posted on Feb 01, 2008
SOURCE: Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Posted on Mar 07, 2009
welcomejee
  • 10594 Answers
SOURCE: Will A Sony Bravia KDL 32s2010 TV purchased in the
This TV will work in Australia as its multi system and auto-power TV.
Posted on Apr 14, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
SONY LCD KDL-S40A12U SWITCHES OFF BY ITSELF
There may be a "Power saving" feature on the TV. Check in set-up and adjust time for auto shut off.
Jan 02, 2018 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do i restore factory settings to Sony Bravia KDL 32w5500?
The old standby for almost all Sony sets is with the set off:
(remote control-Sony)
Display, 5, Volume up, power
With set then on the display should show the tech menu
Press 8 and (set will display or should RESET in red, then press enter and it should (reset) turn green---this has been the standard reset on their set for several decades.
Nov 06, 2012 | Sony BRAVIA KDL32V5500 32 in. TV
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
Sony bravia kdl 32w5500 doesn't switch on, only green light is showing
Try a mains reset on the TV.
- Unplug from the mains.
- Press and hold the power button (on the TV itself) for 20 seconds.
- Plug in a retry.
Unfortunately, failing this, you will need to contact the manufacturer or a local repair person.
Apr 26, 2011 | Sony BRAVIA KDL32V5500 32 in. TV
Sony Bravia KDL-32W5500 no picture no sound
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Feb 02, 2010 | Televison & Video
Is it possible to tune the channels of an integrated freeview digital box within a tv to a recordable dvd player
No!
However, i see what your trying to accomplish - being able to record the freeview pictures you recieve form the Sony inbuilt tuner onto the recorder.. whilst being able to watch a different channel..?!
Well, you cant. If your Recorder has an inbuilt digital tuner then of course this would solve your issues, whereas if it is purely an analouge recorder and your in an area that has switched over then youll need some new hardware unfortunatly,.
Phone Sony on 0845 6000124 local rate number for more advise
Nov 14, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Apr 13, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
SONY BRAVIA -KDF-E50A12U- SENTANTA FREEVIEW TUNING PROBLEMS.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Aug 13, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL32V5500 32 in. TV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
