PLANTRONICS - .AUDIO 995 I tried to pair the headset and USB but will not pair. The headset's blue light will come and blink twice then blink red three times and turn off. I plug the headset into the charging cord but the red light will not come on and is not charging. The computer is up and running and not in sleep mode and is plugged in the ac adapter and not on battery mode.
  • 119 Answers
SOURCE: 1g mp3
that depends, when you bought the mp3 player did it come with an USB charger?
also, do you have to put batteries in it?
if A is true and B is false it is charging, else check the manual or post the actual name of the mp3player in here
Posted on Dec 29, 2007
finess
  • 62 Answers
SOURCE: Computer does not recognize player (Mambo TouchFlix by Kaser Corp.)
if it doesn't create then you probably need to manually add the device. sounds like your plug and play is toggled off for the device. plug it in and go to your control panel and click printers and other hardware. then on the left side menu you should see add hardware. go there and the wizard should detect the device as recently added but not installed and gives you the option to install. let me know if this helps. and good luck
Posted on Feb 10, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
ramon49
  • 111 Answers
SOURCE: My internal battery will not charge
90% of the time the battery is bad. No quick fix, other than test the battery or replace.
please rate
Posted on Mar 26, 2009
SOURCE: Vision: M won't charge
The battery not charging,
I hat the same probleam. Solution reset the unit while is plugged on the Ac charge, turn off and on. will work.
ciao Enzo
Posted on May 11, 2009
Tip
Power button not turning on headset
I'm guessing at some point I pressed down too hard on the power button and either broke something or mis-aligned it to what mattered. <br /> If this happens to you: <ol> <li>Plug the headset into the (connected) USB power cord</li> <li>Blue light comes on</li> <li>Unplug - Headset should remain on</li></ol> <ul> <li> If you leave it plugged in until it turns red (charging) then it will turn off when you unplug it.</li> <li> If your headset doesn't show a blue light or any indication of life, something beyond the power button is wrong.</li></ul>
on Apr 08, 2011 | Plantronics .Audio 995 Digital Wireless...
Is it possible to pair my Plantronics audio 995 with a cell phone? After all it is blue tooth
unlikely as it seems to use blootooth technology but doesnt expose the passcode for the connection. see below.
How do I pair my headset to its USB adapter?
Procedure
Your headset and adapter are already factory pre-paired, and should automatically connect with each other. Should your headset and adapter become unpaired, you can initiate pairing manually. To Pair Your Headset and Adapter:
  1. Start with your headset powered off. Press and hold the power button for about 4 seconds, until the status light rapidly flashes blue. Release the button and set the headset aside.
  2. While the USB adapter is plugged into the computer, pinch the connect/pair button for about 4 seconds, until the status light rapidly flashes blue. Release the button.
  3. The headset and adapter will automatically attempt to pair. If the pairing is successful the status lights will glow solid blue; if unsuccessful, both headset and adapter will stay in pairing mode.
If the pairing was unsuccessful and you want to try to pair again, you must first take your headset and adapter out of pairing mode:
  1. Turn your headset off.
  2. Single press the connect/pair button on the adapter.
  3. Repeat the "To Pair Your Headset and Adapter" procedure, above.
If your headset and adapter are separated and lose their connection after being successfully paired, they will automatically reconnect when they come back into range of each other. If they remain out of range for more than 30 seconds, the headset will go into sleep mode, but will reconnect automatically with the adapter once it is back in range. If the headset is out of range for more than 15 minutes, it automatically shuts off.
Jun 11, 2012 | Plantronics AUDIO 995 WIRELESS HEADSET US
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    Can one get the plantronics audio 995 USB headset (with microphone) to work with the PS3? The headset uses 2.4GHz, not bluetooth, so it's not a bluetooth pairing issue.
    I believe it should work...
    You may want to review this guide for connecting a bluetooth headset to a PS3:
    (Click here)
    http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
    If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
    Dec 14, 2009 | Plantronics .Audio 995 Digital Wireless...
    I have a plantronics 520,
    Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
    Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
    My Plantronics Voyager 510 will not go into pairing mode.
    i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
    Jan 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
    201 people viewed this question
     Grubhead
    Grubhead
