Question about Tomtom ONE GPS Receiver
My Tom Tom memory card doesn't respond when I insert it into device.
  • Anonymous Jan 24, 2009
    shows a picture of a memory card with red x on.
  • Anonymous Feb 19, 2009
    same
  • 3,153 Answers
I red cross usually indicates an SD card problem.
With most tomtom's usually removeing the SD card and powering up will resolve the issue.
If not then a HARD reset without the SD card may be called for.
If it does prove to be an SD card error then formatting in a proper card reader using FAT32 as the file system and then copying the files back over from the tomtom usually does the trick.
Or format and restore from a back up to the card. can work too.
It may also mean that a files might have been deleted or become corrupted.
Ok check and see if your gps has memory card in a slot on the gps (about an inch long and maybe 1/8" wide)
If it has then push the card into the gps and let go
it should come out a little to allow you to remove it.
(do that with the power off !)
power up the gps again and if it works the card is a minor fault that can usualyy be fixed by you pretty easily.
If it still does not come on properly then look for a tiny hole near the SD slot
Get a paper clip and and with the gps switched on pust it into that hole keeping the paper clip straight (dont push too hard)
Hold it for about 3 seconds and release.
your gps should reset itself.
If it stays off try to power it up.
It should now power up but you may have to tell it all your personal settings again.
The tomtoms don't die too often compared to other makes
and even when they lock up they can usually be brought back to life
Posted on Sep 09, 2009
Inky
  • 691 Answers
SOURCE: tom tom one
This would suggest the card may be faulty. If you have a backup of the info on the card, try formatting the card and restoring the data.
Posted on Jul 13, 2007
SOURCE: tom tom one switch on
with tomtom turned on, remove SD card and press RESET, turn off tomtom and insert SD card and start tomtom, problem solved :))
Posted on Dec 09, 2007
SOURCE: Tom Tom Go 720
You have to go into the card on your computer and create a folder called mp3, and a folder called pics. Then your TomTom will see them.
Posted on Feb 04, 2008
SOURCE: when i turn on tom
you need to reboot system
let charge compeltely down
and pull battery if you can then
hook up usb nd insert cdthat came wih unit
keep in mind that yourmemory card could very well be no good
so if my frist steps dont work get a new mem card ok
riard from chicago
Posted on Apr 05, 2008
E61N
  • 515 Answers
SOURCE: maximum memory on SD card for Tom Tom ONE?
Go here:
http://www.tomtom.com/support/product.php?ID=1400&Language=1&query=sd+card+size&FID=2634
Posted on Apr 10, 2008
When i insert mmc card MU13 in my cellphone N70 it says NO CARD INSERTED . In pc it does not respond. Pls give me a solution, there is no way to format.
try to change another memory card to check weather the card you inserted is working or not.
in that case? if the memory card doesn't read by your mobile and also thru your laptop,your memory card might be corrupted or damage....
hope it helps...
Jun 04, 2011 | Nokia N70 Cellular Phone
Tom Tom Go 520 can not connect to PC.
I had the same problem with a 750.
I cured it (accidentally I must add) by inserting a memory card.
I guess the last time I connected and disconnected the 750 it had a memory card in and without one inserted it would not recognise the device.
Strange reason but worked for me.
Jan 10, 2010 | Tomtom GO 700 GPS Receiver
Tom tom go 300
The memory card you have inserted is damaged and needs to be replaced
Jun 30, 2009 | Tomtom GO 300 GPS Receiver
When i turn on the tom tom one
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
Memory card
Replace the SD Card.
Unfortunately not all card makes are compatible. ie: Tesco own brand being one
Good and reliable make is KINGSTON
Put your dodgy card into a pc card ready, copy and paste the data onto the new card.
If that doesn't work then I would say you have a tempromental card reader in your SatNav and need a replacement.
Let me know how you get on.
Mar 31, 2009 | Tomtom GO 510 Car GPS Receiver
Memory card
Complain to Tom Tom ,you may have a lemon,look for law suit soon
May 23, 2008 | Tomtom GO 910 GPS Receiver
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
May 05, 2008 | Tomtom One XL GPS Receiver
When i turn on tom tom it shows insert memory card then it shows red cross
riard from chicago
Apr 05, 2008 | GPS
Tom tom one switch on
Dec 06, 2007 | Tomtom One Europe v2 GPS Receiver
Tom tom one
Jul 12, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom ONE GPS Receiver Logo
450 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
